Integration of rational functions by partial fractions
In summary, when breaking the fraction ((x^3)+x)/(x-1) into partial fractions, we must set up the equation x^3+x=(Ax^2+Bx+C+f(x))*(x-1) and solve for A, B, and C. This results in the final answer of (x^2)+x+2+(2/(x-1)).
alexas
52
The problem is:
((x^3)+x)/(x-1)
And i need to break it into partial fractions...
I tried long division and got:
((x^2) +x )
But the book gives me the answer of:
(x^2)+x+2+(2/(x-1))
Any help would be very much appreciated, thanks.
Well, IF your long division was right, THEN
x^3+x=(x^2+x)*(x-1)
Is that true?
If you are uncertain of the procedure of long division, try to do it as follows:
Since the numerator has highest order 3, and the denominator 1, the highest power of the ratio must be..3-1=2.
We therefore set:
x^3+x=(Ax^2+Bx+C+f(x))*(x-1), where f(x) is some fractional remainder, and A, B, C are constants to be determined.
Multiplying out the right-hand side, and ordering in powers of x, we get:
x^3+x=Ax^3+(B-A)x^2+(C-B)x-C+f(x)*(x-1)
Thus, we must have A=1.
B is therefore also 1, in order to cancel the x^2 term.
C has to be 2, in order for C-B=1
But then, we must have the last equation:
0=-C+f(x)*(x-1),
whereby the remainder f(x)=2/(x-1)
In total then, we get x^2+x+2+2/(x-1) as our answer.
Related to Integration of rational functions by partial fractions
1. What is integration of rational functions by partial fractions?
Integration of rational functions by partial fractions is a method used in calculus to simplify and solve integrals of rational functions. It involves breaking down a complex fraction into simpler fractions, known as partial fractions, which can then be integrated separately.
2. Why is integration of rational functions by partial fractions useful?
This method allows us to solve integrals that would otherwise be difficult or impossible to solve. It is especially useful when the numerator and denominator of a rational function cannot be factored easily, as it provides a systematic approach to solving the integral.
3. What is the process for integrating rational functions by partial fractions?
The process involves the following steps:
  1. Factor the denominator of the rational function into linear or irreducible quadratic factors.
  2. Write the rational function as a sum of partial fractions with undetermined coefficients.
  3. Find the values of the coefficients by equating the original rational function with the partial fraction form.
  4. Integrate each partial fraction separately.
  5. Combine the results to get the final integral.
4. Are there any restrictions or limitations for using integration of rational functions by partial fractions?
Yes, this method can only be used for rational functions with distinct linear or irreducible quadratic factors in the denominator. If the factors are repeated, additional steps such as using long division may be required.
5. Can integration of rational functions by partial fractions be applied to improper rational functions?
Yes, improper rational functions (where the degree of the numerator is greater than or equal to the degree of the denominator) can also be integrated using this method. However, the partial fractions will include a polynomial term in addition to the usual linear or quadratic terms.
  • Calculus
  • Calculus
