Integration of Rational Functions by Partial Fractions
In summary, the student is trying to solve a homework equation but is having difficulty. He is using partial fractions but is unsure of how to proceed. He is having trouble understanding what the problem is asking for. He is looking for help with this and is grateful for any assistance given.
forestmine
203
Evaluate the integral. (Remember to use ln |u| where appropriate.)
∫(x^3 + 36)/(x^2 + 36)
A little bit confused about arriving at the solution for this problem. I get stuck a little ways in. Any help would be greatly appreciated!
First I divided x^3+36 by the denominator, since the power of the numerator is greater. Doing so, I got x + (-36x+36)/(x^2+36). I rewrote my integral as ∫ x + (-36x+36)/(x^2+36).
Now, I want to be able to use some facet of partial fractions, the whole A + B...etc, but I don't really see how I can in this case. If I split up the second half of the integral, I can write it as -36x/x^2+36 + 36/x^2+6^2. Applying b^2-4ac < 0, I know that I won't be able to factor and that I could complete the square in these cases, but I don't really see how that helps me either.
I don't think the problem calls for u-substitution, as I've tried that, and since the problem is part of the partial fractions section, I'm thinking they want us to go about using that method.
I'm not looking for an exact answer, just a little confused about what method to use from here.
Thanks in advance!
You won't be able to, because x2 +36 can't be factored. Break it up as a sum of two fractions:
[itex]\int x dx + \int \frac{-36x}{x^2 + 36} dx + \int \frac{36}{x^2 + 36} dx[/itex]
(You might as well factor out a 36 from the 2 fractions before proceeding.)
You can use a u-substitution from the 1st fraction. The 2nd fraction... needs something else entirely. You familiar with the integrals that involve inverse trig?
I am familiar with inverse trig functions for integrals, and so for the second fraction, I see that if I can get it into the form 1/x^2+1, the integral is simply tan^-1.
So if I factor 36 from each fraction, I get
∫x/(x^2/36+1) + ∫1/(x^2/36 +1)
For the first fraction, u=x/6, du=1/6dx, so I now have ∫36u/(u^2+1) du. Similarly, for the second fraction I get, ∫1/(x^2/36+1). Setting u=x/6 for this fraction as well, and integrating, I get 6tan^-1(x/6).
Now for the first fraction...I'm stuck. I know the solution entails ln(x^2+36) which doesn't make any sense to me, because I thought that x^2+1 suggests we will use tan^-1, as we did in the second fraction.
The u on top in
$$36 \int \frac{u}{u^2+1}\,du$$ is the reason you get a log function. You're over-thinking it a bit. As eumyang said, you can do this one with a simple substitution.
So essentially the u in the numerator cancels with a u on the bottom? And that's why we get the log function?
If you're saying what I think you're saying, that is,
$$\frac{u}{u^2+1} \rightarrow \frac{1}{u+1},$$ then no. Algebra doesn't work that way.
Haha I know, that's why I'm completely confused as to how u/u^2+1 becomes the log function?
Nevermind, I figured it out. It takes another substitution, in this case u^2+1=z.
Thanks
Related to Integration of Rational Functions by Partial Fractions
1. What is "Integration of Rational Functions by Partial Fractions"?
"Integration of Rational Functions by Partial Fractions" is a mathematical technique used to simplify and integrate rational functions, which are functions that are expressed as the ratio of two polynomials.
2. Why is "Integration of Rational Functions by Partial Fractions" important?
This technique is important because it allows us to solve more complex integrals involving rational functions that cannot be easily solved using traditional methods, such as substitution or integration by parts.
3. How does "Integration of Rational Functions by Partial Fractions" work?
The process involves breaking down a complex rational function into simpler fractions, known as partial fractions, and then integrating each of these fractions separately. This is done by finding the appropriate coefficients for each partial fraction using algebraic manipulation.
4. What are the steps for "Integration of Rational Functions by Partial Fractions"?
The general steps for this technique are as follows:1. Factor the denominator of the rational function into linear and/or irreducible quadratic factors.2. Write the rational function as a sum of partial fractions with unknown coefficients.3. Use algebraic manipulation to solve for the unknown coefficients.4. Integrate each partial fraction separately.5. Combine the results to get the final solution.
5. Are there any special cases to consider when using "Integration of Rational Functions by Partial Fractions"?
Yes, there are a few special cases to consider, such as when the denominator has repeated factors or when the rational function is improper (the degree of the numerator is greater than or equal to the degree of the denominator). In these cases, additional steps may be required to solve the integral.
