Integration of tan(x^2), is it possible?
  • MHB
  • Thread starter Saitama
  • Tags
    Integration
In summary, the indefinite integral cannot be found in terms of elementary functions, but it is possible to evaluate it with the help of the McLaurin expansion.
Saitama
4,243
93
This is not a homework problem but something I saw on an another forum. Though the actual problem doesn't require the integral but I am interested to know if it possible to evaluate it.
The indefinite integral cannot be found in terms of elementary functions but is it possible to evaluate:
$$\int_{0}^{\sqrt{\pi}/2} \tan(x^2)dx$$
? (or with different limits?)
I couldn't find anything over the internet and I don't have any idea about the definite integral.
Any help is appreciated. Thanks!
The McLaurin expasion of the function is...
$\displaystyle \tan x^{2} = x^{2} + \frac{1}{3}\ x^{6} + \frac{2}{15}\ x^{10} + ... + \frac{B_{2 n}\ (-4)^{n}\ (1-4^{n})}{(2 n)!}\ x^{2 (2n+1)} + ...\ (1)$
... where the $B_{2 n}$ are the so called 'Bernoulli Numbers'. From (1) You derive...
$\displaystyle \int_{0}^{x} \tan \theta^{2}\ d \theta = \frac{1}{3}\ x^{3} + \frac{1}{21}\ x^{7} + \frac{2} {165}\ x^{11} + ... + \frac{B_{2 n}\ (-4)^{n}\ (1-4^{n})}{\{2 (2 n+1)+ 1 \}\ (2 n)!}\ x^{2 (2n + 1) +1} + ...\ (2)$
For $x= \frac{\sqrt{\pi}}{2}$ the (2) should converge fast enough...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
Ah, that is quite above my current level so I have no idea what are those Bernoulli Numbers but anyways, thanks chisigma! :)
I thought there could be a simpler solution to this but it doesn't look so. :P
FAQ: Integration of tan(x^2), is it possible?
Can tan(x^2) be integrated?
Yes, it is possible to integrate tan(x^2). However, the integration process can be quite complex and may require the use of advanced mathematical techniques.
What is the general method for integrating tan(x^2)?
The general method for integrating tan(x^2) involves substitution, where the variable u is substituted for x^2. This allows for the use of trigonometric identities and techniques such as integration by parts.
Are there any special cases for integrating tan(x^2)?
Yes, there are a few special cases for integrating tan(x^2). For example, when the limits of integration are from 0 to infinity, the integral can be simplified using the Euler-Maclaurin formula.
What are some common mistakes to avoid when integrating tan(x^2)?
One common mistake when integrating tan(x^2) is forgetting to substitute for the variable u. It is also important to use the correct trigonometric identities and to be careful with signs and constants.
Is there a simpler way to integrate tan(x^2)?
There is no one simple method for integrating tan(x^2), but there are some techniques that can make the process easier. These include using symmetry, partial fractions, and trigonometric substitutions.
