Integration of trigonometric function
In summary, the conversation is about solving the integral \int\frac{2x}{x^{2}+6x+13}dx using the substitution method and the fact that \int\frac{f'(x)}{f(x)}dx=ln|f(x)|+C."
Agent M27
171
[tex]\int[/tex][tex]\frac{2x}{x^{2}+6x+13}[/tex]dx
[tex]\int[/tex][tex]\frac{1}{u^{2}+a^{2}}[/tex]du = [tex]\frac{1}{a}[/tex]arctan([tex]\frac{u}{a}[/tex]+c
[tex]\int[/tex][tex]\frac{du}{u}[/tex]=ln(u) + c
u=x+3
2xdu=2x dx
x=u-3
[tex]\int[/tex][tex]\frac{2x}{u^{2}+a^{2}}[/tex]du
=[tex]\int[/tex][tex]\frac{2u-6}{u^{2}+a^{2}}[/tex]du
=[tex]\int[/tex][tex]\frac{2u}{u^{2}+a^{2}}[/tex]du + [tex]\int[/tex][tex]\frac{-6}{u^{2}+a^{2}}[/tex]du
This is where I get stuck because I can only figure out the second integral which turns out to be:
-3arctan([tex]\frac{x+3}{2}[/tex]+c
Basically for the first integral I want to know if this is allowed?
v=u[tex]^{2}[/tex]+a[tex]^{2}[/tex]
dv=2u du
[tex]\int[/tex][tex]\frac{dv}{v}[/tex]=ln(v)
ln(v)=ln(u[tex]^{2}+a^{2}[/tex])=ln((x+3)[tex]^{2}[/tex]+4)+c
So my answer would be the following, which agrees with the book:
ln(x[tex]^{2}[/tex]+6x+13)-3arctan([tex]\frac{u}{a}[/tex]+c
Without checking over your work (which I don't have time to do), I can say that yes, that is allowed. You can always substitute as much as you want so long as you give the answer in the desired form in the end.
u=x+3
2xdu=2x dx
x=u-3
dv=2u du
just remeber
[tex]\int[/tex][tex]\frac{f'(x)}{f(x)}dx=lnf(x)[/tex]
rbnphlp said:
just remeber
[tex]\int\frac{f'(x)}{f(x)}dx=lnf(x)[/tex]
Don't forget the absolute value and the constant of integration.
[tex]\int\frac{f'(x)}{f(x)}dx=ln|f(x)| + C[/tex]
mehh ,whatever
FAQ: Integration of trigonometric function
What is the definition of integration of trigonometric functions?
The integration of trigonometric functions is the process of finding the antiderivative of a given trigonometric function. It involves reversing the process of differentiation and finding the original function that would result in the given trigonometric function when differentiated.
What are the basic trigonometric functions that can be integrated?
The basic trigonometric functions that can be integrated are sine, cosine, and tangent. Other trigonometric functions such as secant, cosecant, and cotangent can also be integrated, but they require more advanced integration techniques.
How is the integration of trigonometric functions useful in real-world applications?
The integration of trigonometric functions is used in various fields such as physics, engineering, and mathematics to solve problems involving periodic motion, such as the motion of a pendulum or a vibrating string. It is also used in the calculation of areas and volumes of irregular shapes and in the analysis of electrical circuits.
What is the general method for integrating trigonometric functions?
The general method for integrating trigonometric functions is to use trigonometric identities and substitution to simplify the integral, then apply integration techniques such as u-substitution or integration by parts. It is important to also consider using trigonometric identities to rewrite the integral in a more manageable form.
What are some common mistakes to avoid when integrating trigonometric functions?
Some common mistakes to avoid when integrating trigonometric functions include forgetting to use the appropriate trigonometric identities, not simplifying the integral before attempting to integrate, and making errors during the substitution process. It is also important to be familiar with the properties of trigonometric functions, such as their even and odd symmetries, to avoid errors when integrating.
