Integration of velocity to get displacement
To find the displacement of a particle moving along the positive x-axis with velocity v = α√x, the correct approach is to integrate velocity with respect to time, not distance. The equation v = dx/dt implies that displacement is determined by integrating v over time. The user initially attempted to integrate with respect to x, leading to incorrect results. Properly applying the relationship between velocity, displacement, and time is crucial for accurate calculations. Understanding these fundamentals is essential for solving the problem correctly.
rudransh verma
A particle at x=0 at time t=0 starts moving along positive x axis with velocity v= alpha## \sqrt x##. Displacement of particle is
##v=\frac{dx}{dt}##.
Integration of v= integration of##(alpha \sqrt x)dx##.
But I am getting wrong answer.
rudransh verma said:
Homework Statement:: A particle at x=0 at time t=0 starts moving along positive x-axis with velocity v= alpha## \sqrt x##. Displacement of particle is
Relevant Equations:: ##v=\frac{dx}{dt}##.
You have the wrong integral. Distance is the integral of velocity with respect to time, not with respect to distance.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 22 ·
  • · Replies 16 ·
