Integration problem deriving virial theorem
In summary, the conversation revolves around the derivation of the virial theorem from the hydrostatic equilibrium equation. The integral $$-\int_0^M\frac{Gm(r)}{r}dm(r)$$ is discussed, with some confusion regarding the notation and the validity of certain steps in the derivation. Ultimately, it is concluded that the integral is the gravitational potential energy of the cloud, and the conversation ends with the understanding that further details can be taken for granted.
Bried
Hello there,
I'm reading a section of my textbook that is deriving the virial theorm from the hydrostatic equilibrium equation. In part of the derivation it states that
$$-\int_0^M\frac{Gm(r)}{r}dm(r)=E_{GR}=-\frac{GmM}{r}$$
When I perform this integral I get the wrong answer. Here's my working.
$$-\int_0^M\frac{Gm(r)}{r}dm(r)=-Gr^{-1}\int_0^Mm(r)dm(r)=-Gr^{-1}\left[\frac12m^2\right]_0^M=-Gr^{-1}\left(\frac12M^2-0\right)=-\frac{GM^2}{2r}$$
I could just move on and take the text for granted but I like to understand how everything is derived so that I don't get tripped up in the future.
I'm not used to seeing $$m(r)$$ in the $$dm(r)$$ but surely the $$(r)$$ could be omitted right? Isn't this just stating that $$m$$ is a function of $$r$$?
Sorry for being a bit of a simpleton but having not done any studying over the summer I seem to have lost my flow somewhat. If someone could point me in the right direction I would be most grateful.
Thanks
Regards
Brian
Bried said:
Hello there,
Is there any additional information on what m(r) represents? It would appear to be the mass at a distance of r units from the center, but that's just a guess. Is there an assumption that the mass increases in a linear fashion?
I don't believe it's valid to treat r as if it were a constant, and bring it outside the integral as you did. dm(r) is the same thing as dm, but emphasizing that m is a function of r. As far as the integration is concerned, I believe that the "of r" part could be omitted, but as I said above, it doesn't seem valid to bring the r out, since m depends on it.
Thanks
Regards
Brian
Hi Mark,
Thanks for getting back to me. Yes, m(r) is the mass of gas contained within a cloud of radius r. I don't believe the text actually states whether the mass increases in a linear fashion. The notation in this new module I'm doing is throwing quite a bit. I recently got a distinction in my Open University level 2 maths so I know I'm more than capable of doing it. I'm so used to evaluating integrals with dx, dt or d anything for that matter but the dm(r) has really confused me and my previous maths course hasn't prepared me for this. I'm feeling rather apprehensive about this module now.
I'm not sure if this will work but here's a dropbox link to the text in the book.
https://www.dropbox.com/s/rteojqv84gulfmd/Virial theorem derivation.jpg?dl=0
Thanks again for your help.
Regards
Brian
In the text on dropbox, they don't evaluate this integral:
##-\int_0^M\frac{Gm(r)}{r}dm(r)=E_{GR}=-\frac{GmM}{r}##
They simply note that it is the gravitational potential energy of the cloud, EGR. I'll have to take their word for it. What they do is to evaluate this integral:
$$3\int_{r = 0}^{r = R} V(r) dP(r)$$
using integration by parts. They result they get from integration is equal to EGR.
Hi Mark,
Thanks for having a look at this again for me. Your response has put my mind at rest and gives me the confidence to carry on through the text without worrying too much about verifying every detail. I did manage to complete the integral on the left hand side, using integration by parts, without any problems.
Regards
Brian
FAQ: Integration problem deriving virial theorem
What is the virial theorem?
The virial theorem is a mathematical relationship that describes the equilibrium state of a system of particles. It states that the average kinetic energy of the particles in the system is proportional to the average potential energy of the system.
What is an integration problem?
An integration problem is a type of mathematical problem where the goal is to find the area under a curve or the volume of a three-dimensional shape. It involves using a mathematical process called integration to solve the problem.
How is the virial theorem derived?
The virial theorem is derived by applying the principle of conservation of energy to a system of particles. By equating the change in kinetic energy of the particles to the change in potential energy, the virial theorem can be obtained through integration.
What is the significance of the virial theorem in physics?
The virial theorem has many applications in physics, such as in the study of celestial bodies, gases, and fluids. It is also used in statistical mechanics to understand the behavior of systems with a large number of particles. The theorem helps to determine the equilibrium state of a system and provides insights into its stability and dynamics.
What are some real-world examples of the use of the virial theorem?
The virial theorem has been applied in various fields, including astronomy, atmospheric science, and engineering. For example, it is used in the study of stars to understand their structure and evolution. In atmospheric science, the virial theorem is used to study the behavior of gases in the Earth's atmosphere. In engineering, it is used to analyze the stability of structures and to design efficient engines.
