Integration question, u substitution
In summary, the problem is evaluating the indefinite integral ∫(√x/(√x-3))dx. The first attempt at a solution involved substituting u for √x-3, but the resulting du did not have a suitable multiple in the integrand. The next attempt involved splitting the integral and using the substitution u=√x-3, which simplifies the problem.
jonc1258
The problem statement
Evaluate the indefinite integral
∫[itex]\frac{\sqrt{x}}{\sqrt{x}-3}[/itex]dx
The attempt at a solution
My first thought was to substitute u for √(x)-3, but then du would equal [itex]\frac{1}{2\sqrt{x}}[/itex]dx, and there's no multiple of du in the integrand.
Next, I tried splitting up the problem like this:
∫[itex]\frac{1}{\sqrt{x}-3}[/itex]*[itex]\sqrt{x}[/itex]
When u is substituted for the [itex]\sqrt{x}[/itex], du still equals[itex]\frac{1}{2\sqrt{x}}[/itex]dx , but the minus 3 in the denominator of the first factor prevents cleanly substituting a multiple of du for [itex]\frac{1}{\sqrt{x}-3}[/itex]dx.
Any ideas or hints?
Notice that if ##u = \sqrt{x} - 3##, then ##u + 3 = \sqrt{x}##.
Since ##\displaystyle du = \frac{1}{2\sqrt{x}} dx, 2\sqrt{x}\ du = dx##
Does this make things easier?
[itex]\sqrt{x}dx= (x/\sqrt{x})dx= (\sqrt(x)^2)(dx/\sqrt{x})= (u+3)^2du[/itex]
The denominator is kind of hard to see, it's sqrt(x)-3. Thanks for all the replies, I'll see if I can figure it out
If [itex]\displaystyle \ \ du=\frac{1}{2\sqrt{x}}dx=\frac{1}{2u}dx\,,[/itex]
then [itex]\displaystyle \ \ dx=2u\,du\ .[/itex]
Any ideas or hints?
FAQ: Integration question, u substitution
What is integration?
Integration is a mathematical operation that involves finding the area under a curve in a graph. It is essentially the reverse of differentiation, which is finding the slope of a curve at a given point.
What is u substitution in integration?
U substitution, also known as the method of substitution, is a technique used to simplify and solve integrals. It involves substituting a new variable, u, for a complicated expression within the integral, making it easier to solve.
When should u substitution be used in integration?
U substitution should be used when an integral involves a complicated expression that cannot be easily solved using other integration techniques, such as integration by parts or trigonometric substitution.
What are the steps for using u substitution in integration?
The steps for using u substitution in integration are: 1) Identify a complicated expression within the integral, 2) Substitute a new variable, u, for that expression, 3) Rewrite the integral in terms of u, 4) Solve the integral using u as the variable, 5) Substitute back in the original variable to get the final answer.
What are some common mistakes to avoid when using u substitution in integration?
Some common mistakes to avoid when using u substitution in integration are: 1) Forgetting to substitute back in the original variable at the end, 2) Choosing the wrong substitution or failing to recognize when u substitution should be used, 3) Making mistakes when differentiating or integrating the expression with u, 4) Forgetting to add the constant of integration at the end.
