Integration using method of substitution
In summary: Then use trigo identities to express the final integrand into something easily integrable.Change the square of the trigo term into a non-square trigo function of a different angle each time you get a sin or cos squared.What is the trigo identity that you are referring to?I'm sorry, but I don't understand. Could you please explain it to me?I don't understand how you get that at all. Could you please explain it to me?In summary, the problem is trying to find the derivate of a function u equal to sin t, and then finding a way to
Ry122
565
Problem:
(tdt)/(4-t^4)^(1/2)
Attempt:
I want the derivate of whatever i make u equal to, to equal something outside of u therefore I will factorize the denominator to equal -(-2+t^2)(2+t^2) and make u equal to (2+t^2) so that du=2tdt
Balance the equation so that one side is equal to the numerator
(1/2)du=tdt
Now I have
1/2[tex]\int[/tex] = 1/(-(-2+t^2)u)^1/2
How do I apply this elementary integral in this situation?:
[tex]\int[/tex] 1/(a^2-x^2)^1/2 dx = sin^-1(x/a) + C
I don't know what to do with the u in
1/(-(-2+t^2)u)^1/2
If it helps the final answer is supposed to be:
(1/2)sin^-1(t^2/2)
Put u=t^2 first. Then you can apply the arcsin formula.
Could you elaborate? Thanks
Uh, u=t^2. du=2*t*dt. There's your t for the numerator. What does the denominator become?
How can u be made to equal t^2? Can't you only make u equal to a whole polynomial, not just part of it?
You can make u whatever you want. What does the denominator become in terms of u?
If u = t^2
then
(-(-2+u)(2+u))^(1/2)?
Yes. But no need to factor it. So now you have (1/2)*du/(4-u^2)^(1/2). Now apply the arcsin formula.
Can the arsin formula only be applied if the variable in the denominator has an exponent of 2?
Yes. But if you do the substitution u=t^2 then the denominator variable does have an exponent of 2. That was the whole point.
Can you tell me how I would go about solving
(sin(t))^4 x (cos(t))^5) dt
if i make u = sin t
du=cost dt
but that doesn't work because cos(t) has an exponent of 5
[tex] sin^4t cos t = (sin^2 t)^2 cos t = \frac{1}{2}^2 (1-cos2t)^2 cos t [/tex]
Expand that out. Change the square of the trigo term into a non-square trigo function of a different angle each time you get a sin or cos squared. (What the heck is that trigo identity called?)
Then make use of some trigo identities to express the final integrand into something easily integrable.
Use cos^2(t)=(1-sin^2(t)).
double angle formula?
How did you get
[tex]
(cos t)
[/tex]
from
[tex]
(cos t)^5
[/tex]
Ok, my mistake it should be [tex] (sintcost)^4 cos t = \frac{1}{2}^4 (sin(2t))^4 cos t = \frac{1}{2}^4 \frac{1}{2}^2(1-cos 4t)^2cos t[/tex]
Just continue from here.
Use these formulae:
[tex]sin(t) cos(t) = \frac{1}{2}sin(2t)[/tex]
[tex]sin^2(t) = \frac{1}{2}(1-cos(2t))[/tex]
FAQ: Integration using method of substitution
1. What is the method of substitution in integration?
The method of substitution is a technique used in integration to simplify complex integrals by replacing the variable of integration with a new variable. This new variable is chosen in such a way that the integral becomes easier to evaluate.
2. How do you perform integration using the method of substitution?
To perform integration using the method of substitution, follow these steps:1. Identify a suitable substitution by looking for a function within the integral that can be easily differentiated.2. Substitute this function with a new variable, making sure to also adjust the limits of integration.3. Simplify the integral using the new variable.4. Integrate the simplified integral using standard integration techniques.5. Substitute back the original variable to get the final solution.
3. What are the benefits of using the method of substitution in integration?
The method of substitution can simplify complex integrals, making them easier to evaluate. It also allows for the use of standard integration techniques, which are often more familiar and easier to use than other methods. Additionally, the method of substitution can help to identify patterns and relationships between functions.
4. Are there any limitations to using the method of substitution in integration?
Yes, there are some limitations to using the method of substitution. It may not always be possible to find a suitable substitution that simplifies the integral. In some cases, the substitution may also introduce new complexities that make the integral more difficult to evaluate.
5. Can the method of substitution be used for definite integrals?
Yes, the method of substitution can be used for both indefinite and definite integrals. When performing integration using the method of substitution for a definite integral, it is important to adjust the limits of integration accordingly after substituting the new variable.
