Integration with Reduction Formula
In summary, the conversation discusses how to solve a given integral I_m using integration by parts. The integral is defined as I_m = \int^{\frac{\pi}{2}} _{0} (cos^m(x))dx, where m is a positive integer. The conversation goes on to show that I_m can be represented as \left( \frac{m-1}{m} \right) I_{m-2} for m \geq 2. The conversation includes attempts at solving the integral and eventually comes to a correct solution by using the chain rule. The conversation also addresses confusion about incorporating limits and includes a reference to an example from lecture notes.
Matty R
83
Hello :smile:
I was hoping someone could help me with this. I'm going round in circles and don't understand how to solve it.
The integral [tex]I_m[/tex] is defined as:
[tex]I_m = \int^{\frac{\pi}{2}} _{0} (cos^m(x))dx[/tex]
By representing [tex]cos^m(x)[/tex] by [tex]cos(x)cos^{m-1}(x)[/tex], show that:
[tex]I_m = \left( \frac{m-1}{m} \right) I_{m-2}[/tex]
,for [tex]m \geq 2[/tex]
Integration by parts
[tex]I = \int^{b}_{a} \left( u \frac{dv}{dx} \right)dx = \left[uv \right] ^{b}_{a} - \int ^{b}_{a} \left( v \frac{du}{dx} \right)dx[/tex]
I've tried using each of the two functions as u and dv/dx, but can't get anywhere.
I would very much appreciate any help with this.
Thanks.
Can you show what you got when you tried dv/dx=cos(x) and u=cos^(m-1)(x) and explain where you're stuck?
Thanks for the reply. :smile:
Part of my problem is that I don't understand how to incorporate the limits for something like [tex]sin^{m-1}(x)[/tex].
[tex]I_{m} = \int^{\frac{\pi}{2}}_{0} \left(cos(x)cos^{m-1}(x) \right)dx[/tex]
[tex]I_{m} = \left[sin(x)cos^{m-1}(x) \right]^{b}_{a}+\int^{b}_{a} \left(sin(x)sin^{m-1}(x) \right) dx[/tex]
[tex]= \left[sin(x)cos^{m-1}(x) \right]^{b}_{a}+J[/tex]
[tex]J = - \left[cos(x)sin^{m-1}(x) \right]^{b}_{a} + I_{m}[/tex]
[tex]I_{m} = \left[sin(x)cos^{m-1}(x) \right]^{b}_{a} - \left[cos(x)sin^{m-1}(x) \right]^{b}_{a} + I_{m}[/tex]
Thats what I get to. I'm not even confident of how I've dealt with u and dv/dx, but I haven't been able to find any information about that. I also don't understand how to get to [tex]I_{m-2}[/tex]
I can follow the example from my tutorials easily enough ((ln|x|)^n), but I'm completely lost with this one.
EDIT
I haven't differentiated properly. I didn't use the chain rule. I'll try again.
Yeah, when you do use the chain rule, it should work out.
Why [tex]J = - \left[cos(x)sin^{m-1}(x) \right]^{b}_{a} + I_{m}[/tex]? Where did you found [tex]sin^{m - 1}\left(x\right)[/tex]?
Yup. I've got it now. I still had a hiccup, with (m - 1) multiplied by a couple of terms, I tried to fully expand it. I think I understand it now.
I found an example applying sin^m(x) in my lecture notes, so I'll use that for applying this integral.
Thanks for your help. :smile:
I think I got it from integrating cos^{m - 1}(x) incorrectly. :redface:
FAQ: Integration with Reduction Formula
What is integration with reduction formula?
Integration with reduction formula is a technique used in calculus to solve definite integrals of functions that have repeated powers of trigonometric or algebraic expressions. It involves using a reduction formula to reduce the power of the expression until it becomes a simple integral that can be easily solved.
When is integration with reduction formula used?
Integration with reduction formula is used when the integrand (the function being integrated) contains a power of a trigonometric or algebraic expression that is greater than 1. It is also useful when solving integrals of functions with repeated powers, such as sin^n x or cos^n x.
What is the reduction formula?
The reduction formula is a mathematical formula that is used to reduce the power of a trigonometric or algebraic expression in an integral. It is derived from the integration by parts formula and is used to simplify the integration process.
How do you use the reduction formula for integration?
To use the reduction formula for integration, first identify the trigonometric or algebraic expression with a power greater than 1 in the integrand. Then, use the reduction formula to reduce the power of the expression until it becomes a simple integral that can be solved. This process may need to be repeated multiple times until the integral can be evaluated.
What are some tips for using integration with reduction formula?
Some tips for using integration with reduction formula include carefully identifying the trigonometric or algebraic expression with a power greater than 1, being familiar with the reduction formula for different expressions, and practicing with various types of integrals to improve proficiency. It is also important to check the final answer by differentiating it to ensure it is correct.
