Interacting Quantum Field Theory: Ground State
In summary, the ground state of an interacting quantum field theory is no longer the non-interacting vacuum. This means that there are states with nonvanishing occupation numbers mixed into the vacuum. These states cannot be interpreted as particles. The energy-momentum relation E2 = m2 + p2 still holds in the interacting theory, guaranteed by Lorentz invariance. However, the definition of "particle" is different in the interacting theory. According to Haag's theorem, the ground state of the interacting theory is orthogonal to every finite-n state of the free theory. On a lattice, there are states with nonvanishing occupation numbers mixed into the vacuum, but they are not interpreted as particles. The energy-momentum relation of the
Gedankenspiel
30
Hi all,
I have a question about the ground state of an interacting quantum field theory.
The state space in non-interacting QFT is a space where each field mode (with specified momentum p) has some occupation number n. These modes are interpreted as n particles with momentum p. The vacuum is the state where all occupation numbers are zero.
In my understanding, if we add interactions, the ground state of the Hamiltonian is no longer the non-interacting vacuum. This means that the interacting vacuum has n-particle states mixed in (n>0). Shouldn't we then be able to measure these particles, which would show up even without any particle coming in? Or can we perform something like a Bogoliubov transformation, such that the real, measurable particles are actually the quasi-particles of the theory? But does the energy-momentum relation E2 = m2 + p2 then still hold in this case?
True.
No. In the interacting theory, it makes no sense to use the free-field theory definition of "particle".
Yes, it's guaranteed by Lorentz invariance.
Likes bhobba
OK, let me be more careful with the word "particle".
Is it correct, that the ground state of the interacting theory has states with occupation number n>0 mixed in?
If the state space of the free field theory is the same as in the interacting theory, this must necessarily be the case.
If not, what is the state space then and why does it change by adding an interaction? The state space of a single non-relativistic oscillator does not change by adding e.g. a quartic term to the potential.
What is the definition of "particle" in the interacting theory if it is different from the free field theory?
Depends. If you have a lattice regulator in place, yes. If you've removed the lattice and gotten a Lorentz invariant theory (usually not possible in 3+1D), then no. According to Haag's theorem, the ground state of the interacting theory is orthogonal to every finite-n state of the free theory (including n=0). But Haag's theorem is only relevant to theories that don't actually exist.
A one-particle state is a state with three-momentum ##\vec p## and energy ##\sqrt{\vec p^2+m^2}##, where ##m## is the mass of the particle.
Likes Gedankenspiel
So on a lattice there are states with nonvanishing occupation number mixed into the vacuum. But they are not to be interpreted as particles.
I wonder how the energy-momentum relation of the noninteracting theory can still hold for although both the Hamiltonian and momentun operators change by adding the interaction.
Related to Interacting Quantum Field Theory: Ground State
1. What is the ground state in interacting quantum field theory?
The ground state in interacting quantum field theory refers to the lowest energy state of a system that is in its lowest possible energy configuration. It is the state in which the quantum fields have the lowest possible amount of energy and are in their most stable configuration.
2. How is the ground state different from the vacuum state?
The ground state and the vacuum state are often used interchangeably, but technically they are not the same. The vacuum state is the state with the lowest possible energy in the absence of interactions, while the ground state is the state with the lowest energy taking into account interactions between particles.
3. How does the ground state affect particle interactions in quantum field theory?
The ground state plays a crucial role in particle interactions in quantum field theory. It determines the stability and properties of particles, as well as the strength of their interactions. The interactions between particles are described by excitations of the ground state, known as quanta, which are responsible for the exchange of energy and momentum between particles.
4. Can the ground state of a quantum field theory be observed?
The ground state of a quantum field theory cannot be directly observed, as it represents the lowest energy state of a system and is not visible to the naked eye. However, its effects can be observed through various physical phenomena, such as the stability and properties of particles, which are influenced by the ground state.
5. How is the ground state of a quantum field theory calculated?
The ground state of a quantum field theory is typically calculated using mathematical techniques such as perturbation theory, mean field theory, or variational methods. These methods involve approximations and assumptions, but they can provide accurate predictions for the properties and behavior of a system in its ground state. Additionally, numerical simulations can be used to calculate the ground state in more complex systems.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
