Interaction between two excited hydrogen atoms
In summary, when calculating the interaction between two excited hydrogen atoms using degenerate perturbation theory, you can construct the total wave function by either adding or multiplying the individual wave functions, depending on the level of interaction between the atoms. However, when evaluating the matrix elements, it is not possible to ignore the radial function as it is an integral part of the wave function.
luxiaolei
75
hi all.
i am trying to calculate the interaction between two excited hydrogen atoms, using degenerate perturbation theory. but comes up a few problems, any helps will be greatly appreciated.
the perturbation has the form:
H`=e3/R3(XaXb+YaYb-2ZaZb)
where the R is the distancee between two atoms and a , b subscripts donates atom a and b respectively.
i need to calculate the matrix elements have the form:
(<ψaψb H` ψaψb>
first thing is how to construct the total wave functions of the two atoms system? they add together or times together? and why? what is the physics meaning of:
ψtotalaψb
ψtotalab
the second is, if using the exzact form, and ignor the radial funtion, is it possible to evaluate the matrix element? i.e
for one atom in its 2 0 0 state and the other in its 2 1 0 state. then wavefunctions equal to theirs spherical harrmonics which are:
2 0 0 state = 1/(2* square root pi )
2 1 0 state = square root 3 /(2* square root pi) * cosθ
couples to one atom in 2 1 0 state and the other in 2 1 1 state
2 1 1 state = squre root (3)/2 * 1/(squre root (2* pi)) * sinθ*ei∅
the first term yields:
∫∫∫2 0 0 state * Xa * 2 1 0 state dr sinθ dθ d∅ *∫∫∫2 1 0 state * Xb * 2 1 1 state dr sinθ dθ d∅
since x= rsinθcos∅ and we have ignored the radial part, how can I evaluate dr ?
above all, am I right for constructing the matrix element like the above way?
Apologise for such a messy question, it is my first time to put equations up here, and I haven't figured out how to construct a complex equation.
Thank you in advance.
Hello,
Thank you for your question. Constructing the total wave function for a system of two atoms can be done in two ways: by adding the individual wave functions or by multiplying them. The choice depends on the physical situation and the type of interaction between the atoms.
If the atoms are far apart and there is no interaction between them, then the total wave function would be the product of the individual wave functions. This is because the atoms are considered to be in a superposition state where their individual states are independent of each other. In this case, the physics meaning of ψtotal = ψaψb is that the wave function describes the probability of finding atom a in state ψa and atom b in state ψb.
However, if the atoms are close enough that there is interaction between them, then the total wave function would be the sum of the individual wave functions. This is because the atoms are now considered to be entangled and their states are not independent of each other. In this case, the physics meaning of ψtotal = ψa+ψb is that the wave function describes the probability of finding atom a in state ψa or atom b in state ψb.
To evaluate the matrix elements, it is not possible to ignore the radial function as it is an integral part of the wave function. The wave function includes both the radial and angular parts, and they cannot be separated. The radial part represents the probability of finding the electrons at a certain distance from the nucleus, while the angular part represents the probability of finding the electrons in a certain direction. Therefore, you cannot ignore the radial part when calculating the matrix elements.
I hope this helps. Good luck with your calculations!
FAQ: Interaction between two excited hydrogen atoms
1. What is the mechanism behind the interaction between two excited hydrogen atoms?
The interaction between two excited hydrogen atoms is primarily governed by the electromagnetic force. As the atoms come close to each other, their positively charged nuclei and negatively charged electrons are attracted to one another, creating a bond between the two atoms.
2. How does the energy level of the excited hydrogen atoms affect their interaction?
The energy level of the excited hydrogen atoms plays a crucial role in their interaction. As the atoms have excess energy, they are more likely to collide and form a bond. This interaction can result in the emission of a photon, which carries away the excess energy.
3. Can the interaction between two excited hydrogen atoms result in the formation of a new molecule?
Yes, the interaction between two excited hydrogen atoms can lead to the formation of a new molecule, known as diatomic hydrogen. This molecule is composed of two hydrogen atoms that have bonded together due to their interaction, resulting in the sharing of electrons and the formation of a stable molecule.
4. How does the distance between the two excited hydrogen atoms affect their interaction?
The distance between the two excited hydrogen atoms plays a crucial role in their interaction. If the atoms are too far apart, the electromagnetic force may not be strong enough to overcome the repulsive force between the positively charged nuclei. On the other hand, if the atoms are too close, the force may be too strong, causing the atoms to fuse together and form a new molecule.
5. Is the interaction between two excited hydrogen atoms a reversible process?
Yes, the interaction between two excited hydrogen atoms is a reversible process. If the atoms are brought close enough together, they will form a bond and create a new molecule. However, if the bond is broken, the atoms will return to their original state, with excess energy being released in the form of a photon.
