svletana
- 21
- 1
I'm trying to do all the calculations for the attached paper, and I'm having trouble with the boundary conditions for P polarization. My question is, how can I arrive to those conditions? The problem is 2D, an infinite dielectric cylinder coated with a layer of graphene, surrounded by another dielectric, and we analyze the cross section as a 2 dimensional problem. This would be for the theory section of the paper only.
I understand that for this mode the conditions are [itex]E_z = 0[/itex] everywhere and [itex]\frac{dH_z}{dr}
\Big|_1 = \frac{dH_z}{dr}\Big|_2[/itex] at the interface (this is condition 1). Also there's the Maxwell equation:
[tex]\nabla \times \textbf{H} = \frac{-i \omega}{c} \textbf{D}[/tex] (condition 2). Also the paper says the tangential component of E is continuous across the interface, and the tangential component of H has a "jump" across the interface that's proportional to the surface current of graphene.
I started with the Maxwell equation, using cylindrical coordinates for the curl and also using that H is in the z direction only:
[tex]\frac{1}{r} \frac{dH_z}{d \phi} \hat{r} - \frac{dH_z}{dr} \hat{\phi} = \frac{-iw}{c} \epsilon \textbf{D}[/tex]
now I calculate the difference between both media and evaluate at the interface, r=R. The dependence of the field on the variable [itex]\phi[/itex] is [itex]e^{i n \phi}[/itex].
[tex] \frac{i n}{R} (H_{z_1} - H_{z_2}) \hat{r} - \left ( \frac{dH_{z_1}}{dr} - \frac{dH_{z_2}}{dr} \right ) \hat{\phi} = \frac{-i \omega}{c} \left ( \epsilon_1 D_1 - \epsilon_2 D_2 \right ) [/tex]
Now, from condition 1 the [itex]\hat{\phi}[/itex] term on the left of the equation should be zero, which tells us the derivatives respect to r are the same for both media, but in the paper there's the epsilons dividing each derivative as well. Also since the tangential component of E is continuous then the right side of the equation is zero as well?
I don't seem to be arriving at the same conditions as they are stated on the paper, and I'm not sure what I'm doing wrong! Interface conditions are hard :(
