Interference and Diffraction of Light
In summary, the green light in the film is a 525 nm light and the frequency of that light is 5.714*1014 Hz. The wavelength of the green light in the film is 380.4 nm. The minimum film thickness that would produce a green reflection is 190.2 nm.
cdhotfire
193
I didnt go to school today, and so missed day of class, now i all lost someone help.
White light is incident normal to the surface of the film as shown below. It is observed that at a point where the light is incident on the film, light reflected from the surface appears green (lamda = 525 nm)
|--Light
|Air [itex]n_{a}=1.00[/itex]
Film [itex]n_{f}=1.38[/itex]
Glass [itex]n_{s}=1.50[/itex]
i. What is the frequency of the green light in air?
ii. What is the frequency of the green light in the film?
iii. What is the wavelenght of the green light in the film?
iv. Calculate the minimum thickness of film that would produce this green reflection.
I know that the light will reflect off when it hits the film, and again when it hits the glass. Thats about all i can see here. [itex]f=\frac{v}{lamda}[/atex] i have the lamda outside but that's it. Can anyone help i don't want to get behind. :smile:
|--Light
ITEM #1:
v = f*λ
::: ⇒ f = v/λ
::: ⇒ f = (3*108 m/sec)/(525*10(-9) m)
::: ⇒ f = (5.714*1014 Hz)
ITEM #2:
In the film, velocity & wavelength change. Frequency does not. Frequency is same answer prev item:
ITEM #3:
iii. What is the wavelength of the green light in the film?
λfilm = λair*nair/nfilm
::: ⇒ λfilm = (525 nm)*(1)/(1.38)
::: ⇒ λfilm = (380.4 nm)
ITEM #4:
The green reflection is caused by CONSTRUCTIVE interference between the ray reflected from the film's top surface with that reflected from the film's bottom surface. Both these rays undergo 180 deg phase shifts from the incident rays at their respective interfaces, so NO net phase shift results from the reflections themselves. However, a phase difference can occur from the added path length traveled by the ray in the film:
{Path Length of Ray in Film} = 2*{Film Thickness}
The minimum film thickness for CONSTRUCTIVE interference occurs when the film ray's path length is exactly {(1.0)*λfilm}. Placing this value into the above equation and solving for minimum film thickness:
{Path Length of Ray in Film} = {(1.0)*λfilm} = 2*{Minimum Film Thickness}
::: ⇒ 2*{Minimum Film Thickness} = (380.4 nm)
::: ⇒ {Minimum Film Thickness} = (190.2 nm) = (0.1902 um) = (1.902*10(-7) m)
thank you very much, would of helped if it was yesturday, i figured it out later on, but many thanks for helping. :biggrin:
FAQ: Interference and Diffraction of Light
What is interference of light?
Interference of light is a phenomenon where two or more light waves interact with each other and either enhance or cancel each other out, resulting in a pattern of bright and dark fringes.
What is the difference between interference and diffraction of light?
Interference and diffraction of light are both phenomena that involve the interaction of light waves, but they differ in the way the waves interact. Interference occurs when two or more waves pass through the same space and interfere with each other, while diffraction occurs when a wave encounters an obstacle and bends around it.
How does the wavelength of light affect interference and diffraction?
The wavelength of light plays a significant role in both interference and diffraction. In interference, the spacing between the bright and dark fringes is determined by the wavelength of light, with shorter wavelengths resulting in more closely spaced fringes. In diffraction, the amount of bending of the wave around an obstacle is also determined by the wavelength, with shorter wavelengths experiencing more bending.
What are some practical applications of interference and diffraction of light?
Interference and diffraction of light have numerous practical applications, including in technologies such as holography, fiber optics, and spectroscopy. They are also used in everyday items such as anti-reflective coatings on glasses and CDs.
How do we observe interference and diffraction of light?
Interference and diffraction of light can be observed through various experiments, such as Young's double-slit experiment and the diffraction grating experiment. They can also be observed in natural phenomena, such as the iridescent colors seen in soap bubbles and oil slicks.
