I Interference by reflection on a CD
A focused beam of light on a CD creates a visible interference pattern, indicating sufficient spatial coherence. This coherence is similar to that seen in lens-focused beams from LEDs or sunlight filtering through a window. Diffused light can still produce color separation, as observed with CDs, soap bubbles, or oil stains, but it lacks the sharp projection seen with coherent light sources. Coherence must be defined carefully, particularly regarding phase uniformity for specific colors traveling different paths. Ultimately, while diffuse sources can show color variations, they do not project them as sharply as point sources.
MaxLinus
TL;DR Summary
Interference by reflection on a CD implies coherence?
A fairly focused beam of light incident on a CD projects a clearly visible interference pattern onto a screen.
May I infer that it has good (or at least enough) spatial coherence?
This property is evident, for example, in a lens-focused beam of light produced by a LED or by a ray of sunlight that filters directly through a half-closed window.
Nonetheless, less intense colour separation can be seen even when diffused light reflects on the CD (or soap bubbles, or oil stains on a rainy day). Would a completely non-coherent light produce such patterns?
Addendum. Found a partial answer in this paper: Coherence properties of different light sources and their effect on the image sharpness and speckle of holographic displays
One must be very careful to define what one means by coherence. In this case one is interested in the phase uniformity for a particular color of light traveling the multiple paths from source to detector required for interference. The CD is a figured mirror. The path of light onto the CD then into your pupil is limited both by the size of your pupil and the characteristics of the source. Your eye will see colors from a diffuse source. A point source will produce colors that project onto a wall. But a diffuse source will not project colors onto the wall.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
