Interference/Difraction wrong consideration
  • Thread starter jaumzaum
In summary, the intensity of the middle fringe is not N times the intensity of the single light sources.
jaumzaum
434
33
Every difraction/multiple slit article I've read until now consider the intensity of the middle fringe to be N times the intensity of the single light sources (in difraction I've divided the slit into n small light sources, that means that N.I0 = I = the intensity of the light reaching the whole slit).
This statement in completelly wrong! It consider that all light beams emmited by each light source does not have a phase difference! This would be a good aproximation if we consider the slit size d to be aproximatelly equal to the wave lenght. But it would still be a aproximation. What if the slit size were very bigger than the wave lenght? Let's say a λ=1000nm, d=1mm and L (distance of the screen to the slit) = 1m. This would give
I = 0.88 I0
The result would be very smaller if d = 2, 3 or 10mm
And all those numbers are plausible (the example I calculated λ=1000nm, d=1mm and L= 1m is even in Tipler's book)
http://img22.imageshack.us/img22/5834/sadgdfgdg.png
The path difference is
θ=[itex](\sqrt{L^{2}+x^{2}}-L)*2\pi/\lambda[/itex]
So we have to integrate Sin[θ] from {x, -d/2, d/2}. The problem is that this integral have to be aproximated. A small aprox for the amplitude A is A0 times
http://img803.imageshack.us/img803/3166/sdgfghg.png
So why the books insist to say the intensity does not change?
Science news on Phys.org
You are right to be concerned about this but it is not always relevant.
For a narrow aperture or array of sources and a long throw (L), that simple assumption is accurate enough to make the approximation. Look up Fraunhoffer and Fresnel Diffraction to see this discussed in high or low detail - depending on what you want. Here is one link which discusses the problem.
In some cases there is a further consideration and that is that the elements in an array of diffracting sources may not all even 'point' in the same direction; they may not even be considered as point (omnidirectional) sources. Arrays of radio antennae often have non-parallel elements but then, one is more likely to be considering the Fraunhoffer region rather than the near field.
FAQ: Interference/Difraction wrong consideration
What is interference/diffraction wrong consideration?
Interference/diffraction wrong consideration is a common mistake made when studying the phenomenon of interference and diffraction in waves. This refers to situations where the assumptions made about the wave properties are incorrect, leading to incorrect conclusions about the behavior of the waves.
What are some examples of interference/diffraction wrong consideration?
One example is when the wave is assumed to be monochromatic (having a single wavelength) when it is actually a mixture of multiple wavelengths. Another example is when the wave is assumed to be propagating in a single direction when it is actually traveling in multiple directions.
How does interference/diffraction wrong consideration impact scientific research?
This mistake can lead to incorrect interpretations of experimental results and can hinder the progress of scientific research. It is important for scientists to be aware of this potential error and to carefully consider all assumptions made in their experiments.
What measures can be taken to avoid interference/diffraction wrong consideration?
To avoid this mistake, scientists should carefully consider the assumptions made about wave properties and test them through various experiments. It is also important to use advanced mathematical models and techniques to accurately analyze the behavior of waves.
Are there any real-life applications affected by interference/diffraction wrong consideration?
Yes, this mistake can have significant impacts in fields such as optics, acoustics, and signal processing. For example, incorrect assumptions about the properties of light waves can lead to errors in designing optical devices such as lenses and mirrors.
