Interference Fringes in a Diffraction envelope
In summary, the conversation is discussing a diffraction experiment with two slits, with a de Broglie wavelength of 45 pm, a distance of 1.95m from the slits to the detection plane, and a slit width of 1 micrometer. The question is asking how many interference fringes fit in the diffraction envelope and the answer is 2m_c+1, with m_c being the largest integer less than the point where the diffraction envelope first goes to zero. The diffraction envelope gets multiplied by the interference pattern intensity result, giving zero intensity for certain values of m, such as m=8 in this case. This is due to a computation/superposition of the phases at each location,
Yoki
My question is at https://imgur.com/a/lDOUzjY . The de Broglie wavelength of the atoms in question is 45 pm. The distance from the slits to the detection plane is 1.95m. Each slit width is 1 micrometer. The distance between the slits is 8 micrometers.
2. Homework Equations
y_{min} = λL/a where λ is the wavelength, L is the distance between the slits and the detection plane, and a is the slit width. This is for a minimum in a diffraction experiment.
The width of the diffraction envelope is 2y=2(λL/a)=175.5 micrometers where y is the distance from the central maximum to the first minimum(either above or below it). My question is about the number of interference fringes that fit in the envelope. Is it the intersection of the two diffraction envelopes of the two slits and not the single slit envelope of the first part?
Usually the letter ## b ## us used for slit width. The diffraction envelope has its zeros when ## m \lambda=b \sin(\theta) ## with integer ## m \neq 0 ##. The question is asking how many maxima do you find between the ## \theta ## corresponding to ## m=-1 ## and ## m=+1 ##. The maxima of the interference pattern are found where ## m \lambda=d \sin(\theta) ##, and this time integer ## m=0 ## is included. Here ## d ## is the distance between slits. ## \\ ## You need to find the largest ## m=m_c ## where ## \theta ## is still less than the place where the diffraction envelope first goes to zero that you found above. Then to count how many maxima you have including ## m=0 ## inside that envelope. That count is a very simple ## 2m_c+1 ##. ## \\ ## And let me give you what may be a helpful hint: I think you will find that ## m=8 ## of the second part lands right on the ## m=1 ## of the first part. Here, that maximum will not appear because the diffraction envelope gets multiplied by the interference pattern intensity result (for very narrow slits or point sources), giving zero intensity there. It should be fairly obvious what ## m_c ## is. And note that the wider the slit, the narrower the diffraction envelope becomes. Point sources and thin slits have very wide diffraction envelopes.
Likes Yoki
Charles Link said:
Usually the letter ## b ## us used for slit width. The diffraction envelope has its zeros when ## m \lambda=b \sin(\theta) ## with integer ## m \neq 0 ##. The question is asking how many maxima do you find between the ## \theta ## corresponding to ## m=-1 ## and ## m=+1 ##. The maxima of the interference pattern are found where ## m \lambda=d \sin(\theta) ##, and this time integer ## m=0 ## is included. Here ## d ## is the distance between slits. ## \\ ## You need to find the largest ## m=m_c ## where ## \theta ## is still less than the place where the diffraction envelope first goes to zero that you found above. Then to count how many maxima you have including ## m=0 ## inside that envelope. That count is a very simple ## 2m_c+1 ##. ## \\ ## And let me give you what may be a helpful hint: I think you will find that ## m=8 ## of the second part lands right on the ## m=1 ## of the first part. Here, that maximum will not appear because the diffraction envelope, (the wider the slit, the narrower the diffraction envelope), gets multiplied by the interference pattern intensity result (for very narrow slits or point sources), giving zero intensity there. It should be fairly obvious what ## m_c ## is.
m_c = 7
Thank you
Likes Charles Link
Yoki said:
m_c = 7
If this is a homework assignment, your teacher will want you to show your work though of what happens for ## m=8 ##.
Likes Yoki
Why does the diffraction envelope get multiplied by the interference pattern intensity result?
This follows from a computation/superposition to compute the total electric field, keeping track of the phases at each location including taking account of the phase difference that will occur across the different positions off the individual slits. For the case of slits with identical widths, the computation results in a common factor that occurs in all of the slits which is the diffraction envelope. The remaining factor is the interference pattern factor from the slits being treated as point sources. I will try to find you a "link"... Try this: https://sites.uAlberta.ca/~pogosyan/teaching/PHYS_130/FALL_2010/lectures/lect36/lecture36.html
Likes Yoki
Related to Interference Fringes in a Diffraction envelope
What are interference fringes in a diffraction envelope?
Interference fringes in a diffraction envelope are patterns of light and dark bands that are created when two or more light waves interfere with each other. These fringes can be observed when light passes through a narrow slit or is diffracted by a grating.
How are interference fringes in a diffraction envelope formed?
Interference fringes in a diffraction envelope are formed when two or more coherent light waves interfere with each other. This interference can be constructive, where the waves add up and create bright fringes, or destructive, where the waves cancel out and create dark fringes.
What is the significance of interference fringes in a diffraction envelope?
Interference fringes in a diffraction envelope are important in understanding the wave nature of light and can be used to measure the wavelength of light. They also have practical applications, such as in diffraction gratings used in spectrometers and in interferometers used for precise measurements.
What factors affect the visibility of interference fringes in a diffraction envelope?
The visibility of interference fringes in a diffraction envelope can be affected by several factors, including the wavelength of light, the width of the slit or grating, and the distance between the source of light and the diffraction pattern. The visibility can also be affected by the coherence of the light source.
How can interference fringes in a diffraction envelope be used to determine the wavelength of light?
Interference fringes in a diffraction envelope can be used to determine the wavelength of light by measuring the distance between adjacent fringes and using the formula d sinθ = nλ, where d is the distance between slits or grating, θ is the angle of diffraction, n is the order of the fringe, and λ is the wavelength of light.
