Interference in light rays due to phase difference
In summary: Having a head start and traveling a greater path both make A lead MORE. In fact, the length of path B is a free variable in this problem. Let path B have length 0. Then path A would have length length 100m. This would mean that B goes through zero change in phase and stays at phase = 0. A goes through 100m, which is equivalent to 100/400 wavelengths, which means it goes through another pi/2 radians. Since A already starts out at pi/2, this means A, which will be at a phase of pi/2 + pi/2 at point D, leads B by pi.The extra 100m in path A means that by the time light from A has
sabinscabin
let there be three points: A, B, and D. Light of wavelength 400 m is emitted from the source at A to the destination D, and also from B to D. Line segment AD is 100 m longer than BD. The starting phase of the light at A is pi/2 radians ahead of B. At point D, what is the phase difference between the light rays?
none really. Just that path length differences cause phase differences.
Let the phase of light at the source B be 0. The starting phase at A is then pi/2. Light ray A also goes through 100/400 more wavelengths than light B since it has to go through a longer distance. This is equivalent to another pi/2 radians. Therefore at point D, light ray A leads B by pi radians.
This is actually a problem from Halliday and Resnick, 8th edition, chapter 35 number 21. The back of the book says the answer is 0, but I have no idea why they took pi/2 - pi/2 instead of pi/2 + pi/2.
Light ray A started out with a lead of pi/2, so AD being pi/2 longer than BD leaves A and B in-phase at D.
Keep track of your signs when dealing with phase.
Regards,
Bill
Regards,
Bill
believe me, I'm trying as hard as i can to work out the phase shifts, both due to A having a head start and A traveling a greater path, as having opposite signs, but I just can't do it.
I'm positive that halliday and resnick has made an error on their part for this problem.
Here's the exact wording for this problem:
Sources A and B emit long-range radio waves of wavelength 400 m, with the phase of the emission from A ahead of that from source B by 90 degrees. The distance Ra from A to detector D is greater than the corresponding distance Rb by 100 m. What is the phase difference of the waves at D?
The extra 100m in path A means that by the time light from A has reached the detector, B has undergone a pi/2 phase change to be in phase with A, so the total phase difference is zero. B leads A in path difference because it is closer to the detector, and this makes up for the initial phase lead in A.
"Leading phase" has to do with time. If A and B are emitted at the same time, A's phase is pi/2 relative to B (assuming positive-increasing phase convention). When you translate the phase references to D, A's path is pi/2 longer. When you subtract off the electrical path length to get the phase at D, A shifts back to zero relative to B.
If A were "lagging" by pi/2, then the phase of A at D would be -pi relative to B.
Regards,
Bill
FAQ: Interference in light rays due to phase difference
What is interference in light rays due to phase difference?
Interference in light rays due to phase difference is a phenomenon where two or more light waves interact with each other, resulting in either constructive or destructive interference. This occurs when the peaks and troughs of the waves are either aligned or misaligned, causing a change in the overall intensity of the light.
How does phase difference affect interference in light rays?
Phase difference refers to the difference in the timing of the peaks and troughs of two light waves. When the peaks and troughs are aligned, the waves are said to be in phase, resulting in constructive interference and a brighter light. When the peaks and troughs are misaligned, the waves are said to be out of phase, resulting in destructive interference and a dimmer light.
What is the difference between constructive and destructive interference?
Constructive interference occurs when the peaks and troughs of two light waves are aligned, resulting in a brighter light due to the waves reinforcing each other. Destructive interference occurs when the peaks and troughs are misaligned, resulting in a dimmer light due to the waves canceling each other out.
What are some real-life examples of interference in light rays due to phase difference?
One example of this phenomenon is the colorful patterns seen on soap bubbles or oil slicks. The different thickness of the layers causes phase differences in reflected light, resulting in interference patterns. Another example is the rainbow, where the sunlight is refracted and reflected in water droplets, causing interference and the separation of colors.
How is interference in light rays due to phase difference used in technology?
Interference in light rays due to phase difference is used in various technologies, such as interferometers, which are used in scientific instruments to measure small changes in distance or wavelength. It is also used in anti-reflective coatings on lenses and solar cells to reduce unwanted reflections and increase efficiency. Additionally, it plays a crucial role in fiber optics, where light waves are guided through thin fibers and can be manipulated through phase differences to transmit signals.
