Interference of light in thin films
In summary: I think you are not getting the point I am making.if the difference is ##\pi##, your equation should be ##\Delta \phi=2\pi m=\frac{2\pi}{\lambda_{min}}*2nd\pm\pi##. I.e., you do not at this stage know which way the difference is.So your answer becomes ##\pm 100nm##, and you have to choose the sign that makes sense.
jerry222
Suppose we have a thin oil film (n=1.5) in air. The light strikes the film vertically. We use a spectrometer to see that an intensity maximum at wavelength of 600nm and a minimum at 300nm. And there is no minima inbetween. How thick is the film?
\delta=(2pi/lamda)
Phase difference is $\phi=\frac{2pi}{\lambda}* \Delta+\pi$
Phase difference, max: $\Delta \phi=2pim=\frac{2pi}{\lamda_{max}}*2nd$
Phase difference, max: $\Delta \phi=2pim=\frac{2pi}{\lamda_{min}}*2nd+pi$
Flim thickness: $d=100nm$
Set the equations equal to each other i got a d=-100nm which is strange. Can someone help?
jerry222 said:
Homework Statement:: Suppose we have a thin oil film (n=1.5) in air. The light strikes the film vertically. We use a spectrometer to see that an intensity maximum at wavelength of 600nm and a minimum at 300nm. And there is no minima inbetween. How thick is the film?
Relevant Equations:: ##\delta=(2\pi/\lambda)##
Phase difference is ##\phi=\frac{2pi}{\lambda}* \Delta+\pi##
Phase difference, max: ##\Delta \phi=2pim=\frac{2pi}{\lamda_{max}}*2nd##
Phase difference, max: ##\Delta \phi=2pim=\frac{2pi}{\lamda_{min}}*2nd+pi##
Flim thickness: ##d=100nm##
I tried fixing up your LaTeX but it still isn’t making much sense:
Phase difference is ##\phi=\frac{2\pi}{\lambda}* \Delta+\pi##
Phase difference, max: ##\Delta \phi=2\pi m=\frac{2\pi}{\lambda_{max}}*2nd##
Phase difference, max: ##\Delta \phi=2\pi m=\frac{2\pi}{\lambda_{min}}*2nd+\pi##
Don't you mean Phase difference is ##\pi##?
Anyway, a difference is unsigned, so in the equation it's ##\pm\pi##.
yeah where pi is the phase change due to refraction and reflection
So which sign should you select?
ah i got -100nm, the correct answer is 100...i just set those two eaquations equal to each other, that s what i wanted to ask...
Likes Delta2 and jerry222
ahhhhhhhhh Thank You !
Likes Delta2
