Interference & Diffraction in Double Slit Experiment
In summary, the conversation discusses the relationship between diffraction and interference in a double slit experiment. Diffraction is the general term for any effect on a wave front, while interference is a simplified model that explains the main features of a diffraction pattern. It is believed that in the single slit experiment, diffraction occurs due to interference at the slits, while in the double slit experiment, the light rays from both slits interfere constructively or destructively as a result of diffraction. However, it is important to note that both diffraction and interference play a role in creating the overall diffraction pattern. The conversation also touches on the limitations of the Huygens model of elementary waves and the significance of interference in obtaining a diffraction pattern
Josielle Abdilla
50
In a double slit experiment, is diffraction caused by interference or interference is caused by diffraction?
Likes Philip Koeck
Science news on Phys.org
Your question is puzzling.
Go back and look at the single slit. Do you think the diffraction from it is "caused" by "interference"? If you think it is, then you need to explain where this interference is coming from.
So now, translate that to the double slit.
BTW, just a friendly hint, don't ever just post one single, terse sentence when you ask question like this. Provide some context, and in this case, provide a sensible reason why you would ask a question like this so that we know where you're coming from. Otherwise, when I look at a "naked" question like this, I have no idea if you even know what the concepts of "diffraction" and "interference" are. Often times, many of us trying to respond to such questions waste our time just trying to understand the question and trying to decipher what you already know.
So help us to help you.
Zz.
Likes nasu and berkeman
This is just the dreaded 'use of words'. Diffraction is the general term to describe any effect on a wave front. It can be as complicated or as simple as your choose. Interference (imho) is a simplified model which allows us to get the main features of a diffraction pattern by treating the source as a small number (perhaps just two) of points / omnidirectional sources. Young's slits came first in History because it's a simple problem.
We are taught about interference first because it's easy to describe and doesn't require Integral Calculus which the full 'diffraction' treatment uses.
Thanks a lot for your help! However, is it true that in the single slit experiment, diffraction happens due to interference at thr slits, whilst in the double slit experiment, the light rays from both slits interfere constructively/destructively as a result of diffraction ?
Thanks a lot !
Josielle
Thanks a lot !
Josielle
A slit of finite width has its own diffraction pattern. Two identical slits each have identical diffraction patterns and the resulting pattern (in a simple case like this, at least) can be calculated fairly accurately by 'multiplying' the diffraction pattern by the (simplified) two slit interference pattern.
I am referring to the pattern at 'infinity' - say on a distant screen. The near field is more complicated to work out.
I think you should step back at this point and re-focus. It's ALL Diffraction which can be calculated by assuming a vast number of points across a slit and doing an Interference calculation between all those points and summing the result (Integral Calculus). You can work out simple diffraction due to narrow slits by just doing the Interference calculation assuming two infinitely narrow slits ('point sources', if you like).
Thanks a lot !
Josielle
You have not understood either of them. There are signatures of the single slit in the double slit pattern.
Look at the picture that I posted in this post:
https://www.physicsforums.com/threads/a-view-of-the-double-slit-experiment.945168/#post-5981866
Zz.
Thanks a lot !
Josielle
Hi Josielle.
I think you're asking a really good question. I get the impression that you are not really satisfied with the model of Huygens elementary waves in textbooks and I agree sort of, although I also have to say that the model works quite well.
I'd like to start with a different example: If a plane wave (light for example) hits some very small objects then every object can become the source of a spherical wave. I would call this process scattering, but I guess diffraction is also correct. In any case, these spherical waves and the plane wave all interfere with each other and you'll get a diffraction pattern on a screen or detector placed at some distance from the objects. So you see that interference is important for getting the diffraction pattern.
Now let's replace the small objects with small holes in a screen. Now the plane wave cannot pass through anymore and the diffraction pattern you see is due to interference between spherical waves coming from the holes. It's not completely clear why a hole would lead to a spherical wave the same as a small object does. Maybe a good explanation is that oscillations in the edge of the hole cause the spherical wave.
If you now think of a single large hole or slit the model becomes even stranger. Now every point in the hole or slit is supposed to be the source of an elementary wave. If you add up these waves correctly (taking into account constructive and destructive interference) you get the diffraction pattern of a hole or a slit at a large distance. Again I would say interference between the elementary waves is necessary to get the diffraction pattern.
What's really strange is the idea that elementary can come from inside the hole. There is nothing there, so what is producing the waves? There are other explanations where the interaction between light and the hole or slit only happens at the edge, but these so-called boundary diffraction models are more difficult to work with.
Please don't stop asking questions.
Thanks a lot. This means a lot for me ☺️☺️
FAQ: Interference & Diffraction in Double Slit Experiment
What is the double slit experiment?
The double slit experiment is a classic experiment in physics that demonstrates the wave-like nature of light. It involves shining a light source through two parallel slits and observing the resulting interference pattern on a screen.
What is interference in the double slit experiment?
Interference is the phenomenon that occurs when two or more waves overlap and interact with each other. In the double slit experiment, the light waves passing through the two slits interfere with each other, creating a pattern of bright and dark bands on the screen.
What is diffraction in the double slit experiment?
Diffraction is the bending of waves around obstacles or through small openings. In the double slit experiment, the light waves passing through the slits diffract and spread out, creating the interference pattern on the screen.
How does the distance between the slits affect the interference pattern in the double slit experiment?
The distance between the slits, also known as the slit spacing, affects the interference pattern by determining the spacing between the bright and dark fringes. A smaller slit spacing will result in a wider interference pattern with more fringes, while a larger slit spacing will result in a narrower interference pattern with fewer fringes.
What is the role of wavelength in the double slit experiment?
The wavelength of the light used in the double slit experiment affects the spacing between the fringes in the interference pattern. A shorter wavelength will result in a wider interference pattern with more fringes, while a longer wavelength will result in a narrower interference pattern with fewer fringes.
