Interference pattern with some fringes missing
In summary, the conversation discusses the possibility of creating an interference pattern with missing bright fringes and equal intensity remaining ones. This can be achieved through the use of an inverse Fourier transform of a desired pattern, but this process can be challenging due to certain technical limitations. One potential solution mentioned is using two beams to create a 1D photonic structure in a photorefractive material, then breaking the periodicity by creating at least one missing fringe in the pattern. Other methods for achieving this goal are also being explored.
russel.arnold
41
hi
i was wondering whether we can produce a interferece pattern with some bright fringes missing( i.e not appearing at all). If yes..how it can be achieved?:confused:
Science news on Phys.org
also i want that the intensity of the remaining bright fringes should be same :redface:
Sure- that's an active field of engineering- creating a specific far-field diffraction pattern.
Since the far-field pattern is the Fourier transform of the exit pupil, what is done (in principle) is to start with the desired pattern (in this case, say sin(x)*(1-rect(x)) which is a sine wave with the central fringe missing), and perform an inverse Fourier transform.
In practice, this is tricky since (1) there are zeroes in the function and (2) the transforms have to be complex (phase-only gratings), and (3) manufacturing currently produces diffracting objects with discrete levels of phase retardation.
There was a company in Huntsville, AL that does this (but maybe not your specific application):
http://jenoptik-inc.com/microoptic-solutions/diffractive-optical-elements.html
@ andy sir
thanks for the reply..
well basically my problem is to create a 1 D photonic structure using optical induction (in a photorefractive material). Since it is sensitive to light, we will create the interfernce pattern using 2 beams which || give rise to 1D spatially varying periodic refractive index structure. Now nxt step is to break this periodicity. So..we must have atleast one missing fringe in the corresponding pattern.
Can u suggest some more possibe ways to carry out this??
Yes, it is possible to produce an interference pattern with missing fringes. This can occur if there is a disturbance or obstruction in the path of the interfering waves. For example, if one of the sources of the waves is blocked or if there is a change in the medium through which the waves are traveling, it can result in missing fringes in the interference pattern. This can also be achieved intentionally by manipulating the setup of the experiment, such as by adjusting the distance between the sources or changing the wavelength of the waves. It is important to carefully control and monitor these factors in order to accurately study and analyze the interference pattern.
FAQ: Interference pattern with some fringes missing
What is an interference pattern with some fringes missing?
An interference pattern with some fringes missing is a phenomenon that occurs when two or more waves overlap and interfere with each other, causing some areas of the pattern to have more intensity (bright fringes) and other areas to have less intensity (dark fringes).
What causes fringes to be missing in an interference pattern?
Fringes can be missing in an interference pattern due to destructive interference, where the peaks of one wave cancel out the peaks of another wave, resulting in a decrease in intensity. This can also occur when the waves are out of phase and the peaks of one wave align with the troughs of another, causing cancellation.
How can an interference pattern with missing fringes be used in scientific research?
An interference pattern with missing fringes can be used in many scientific fields, including optics, quantum mechanics, and radio astronomy. It can provide valuable information about the properties of waves, such as their frequency and wavelength, and can also be used to study the behavior of particles, such as electrons.
Can an interference pattern with missing fringes be seen in everyday life?
Yes, an interference pattern with missing fringes can be seen in many everyday situations. For example, when sunlight passes through a small opening, it can create an interference pattern with bright and dark fringes. This can also be seen in soap bubbles, oil slicks, and other thin films.
How can an interference pattern with missing fringes be manipulated or controlled?
An interference pattern with missing fringes can be manipulated or controlled by adjusting the properties of the waves, such as their amplitude, wavelength, and phase. This can be done through the use of diffraction gratings, polarizers, and other optical components. It can also be controlled by changing the distance between the sources of the waves.
