Fawzi Da
- 11
< Mentor Note -- Poster has been reminded to use the Homework Help Template and show their work on schoolwork problems >
Hello everyone I have some questions on engine calculations that I need help in please.
1) A reciprocating internal combustion engine operates on a 4 stroke cycle. If the engine's crankshaft is rotating at 5,985 rev/min, calculate the number of engine cycles completed every second
(note that I tried 5985/60 and that gave me a wrong answer)
2) An engine has a crank radius of 41mm. If the engine's crankshaft is rotating at 2131 rev/min the calculate the mean piston speed (m/s)
3) For an engine:
-Operating at speed of 2151 rev/min
-Having a crank radius of 41 mm
-Having a connect a connecting rod length of 136 mm
When the crankshaft has rotated 84 degrees from top dead centre, calculate the velocity of the piston, u (m/s), in the x-axis direction.
(why isn't the velocity 0 m/s since the piston only move in the y axis?)
4) An engine has the following geometry:
-A bore of 75 mm
-A stroke of 70 mm
-A ratio of connecting rod length to crank radius of of 3.8 m/m
Calculate the rate of change of volume (m^3 / rad) when the crankshaft has rotated -30 degrees from top dead centre
Thank you in advance
3) For an engine:
-A bore of 75 mm
-A stroke of 70 mm
