Othin
- 36
- 1
We are asked to derive the expression for the internal energy of an ideal Fermi degenerate gas using Sommerfeld expansions, writing out terms up to the fourth order in ##(\frac{T}{T_F} )## , that is, we must determine ## \alpha ## in the following expression: $$ U= \frac{3}{5}N\varepsilon_F \left\{ 1 + \frac{5\pi ^2}{12} {\left( \frac{T}{T_F}\right)}^2 + \alpha {\left( \frac{T}{T_F}\right)}^4 \right\}$$
The method is basically the one used in the text of Kubo on Statistical Mechanics.
We're treating the 3-D "particle in a box" model with periodic boundary conditions, so that the energy spectrum is given by: $$\varepsilon_k = \left( \frac{\hbar^2 k^2}{2m} \right) , k=\left( 2n\pi /L \right)$$
We are also supposing that the number of particles is sufficiently large for we to approximate the summations characteristic of a discrete spectrum by integrals. We then have:
N= \gamma V \int_0^\infty D(\varepsilon)f(\varepsilon) d\varepsilon, \\
U= \gamma V \int_0^\infty \varepsilon D(\varepsilon)f(\varepsilon) d\varepsilon \\
where ## \gamma ## takes the spin degeneracy into account and:
D( \varepsilon ) = \frac{1}{4 \pi^2} {\left( \frac{2m}{\hbar ^2} \right)}^{3/2} \varepsilon ^{1/2} \equiv C \varepsilon ^{1/2} ,\ \ f(\varepsilon) = \frac{1}{exp[\frac{\varepsilon - \mu}{k_bT}] + 1}.
The Sommerfeld expansion is also given, whereby we can solve integrals of the form ## I = \int_0^\infty f(\varepsilon) \psi(\varepsilon) d{\varepsilon}## :
I = \int_0^{\mu}\psi(\varepsilon) d\varepsilon + \frac{1}{2!}I_2 {\left( \frac{d \psi}{ d \varepsilon} \right)}_{\varepsilon= \mu} + \frac{1}{4!}I_4 {\left( \frac{d^3 \psi}{ d\varepsilon^3} \right)}_{\varepsilon= \mu} + ...
Within approximations, the integral ##I_2## and ##I_4## are taken to equal, respectively, ## \frac{\pi^2 (k_bT)^2}{3} ## and ## \frac{7 \pi^4}{15}(k_bT)^4##
[/B]
Since U must be given in powers of ##T/T_F ##, we must first use the equation for N in order to write #/mu# in terms of T and #T_F#. Therefore, for N:
\psi(\varepsilon) = \varepsilon^{1/2} \implies N = \gamma VC \left \{ \frac{2}{3}\mu^{3/2} + \frac{\pi ^2}{12} (k_b T)^2 \mu^{1/2} - \frac{3}{8} \frac{1}{4!} \mu^{\frac{-5}{2}}I_4 + ... \right \} \\
\frac{N}{\gamma VC}= \frac{2}{3} \mu^{3/2} \left[ 1 + \frac{\pi^2}{8}\left (\frac{k_b T}{\mu} \right)^2 + \left( \frac{7 \pi^4}{640} \right) \left (\frac{k_bT}{\mu} \right)^4 \right]
Now, after this expression Kubo (and other books I've checked) make some kind of expansion around ## \mu_o ## and arrive at the following expression:
\mu = \mu_o \left[1- \frac{\pi^2}{12} \left( \frac{k_b T}{\mu_o}\right)^2 - \frac{\pi^4}{80} \left( \frac{k_b T}{\mu_o}\right)^4 \right]
and , no matter how I try, I can't get anything like that last expression (I managed to get the first term by truncating the series and using a binomial expansion to the first order, but when I include the next power I can't make it work)
