Internal forces on a system of particles
In summary, the conversation discusses the concept of forces of action and reaction and how they do not cancel out each other, but the internal forces within a system of particles do cancel out in pairs. It is important to consider the chosen system when analyzing internal forces, as they may appear to cancel out in certain situations. The conversation also mentions the use of animations and the importance of understanding the system when dealing with internal forces.
johncena
131
I am very much confused with this statements
"The forces of action and reaction never cancels out each other , but the internal forces on a system of particles cancel out in pairs "
I think i know the reason for the first statement.i.e,The forces of action and reaction are acting on different bodies, and hence they does not cancel each other.
But what about internal forces ? Aren't they acting on different bodies ? then how can they cancel out each other ?
Let's say there are two bodies, A and B. A and B exert forces on each other which are equal and opposite. If you take your system to be A by itself, then the force that B exerts on A is an external force which contributes to the net force on A.
But if you take your system to be both objects together (A+B), then the forces that A and B exert on each other are internal forces. When you want the net force on the system A+B, those internal forces 'cancel out' since the force on A from B is exactly opposite to the force on B from A.
Make sense?
I think i am still in confusion...
If you don't mind, can you demonstrate it by an animation ?
I don't know what you mean by 'an animation', but here's another attempt.
Lets say that B exerts a force +F on A, thus A exerts a force of -F on B. Let's assume that those forces are the only forces in the problem.
What's the net force on A? Answer: +F
What's the net force on B? Answer: -F
What's the net force on 'A+B' taken as a system? Answer: Just add the force on A (+F) and the force on B (-F) to get the total force on the system, thus +F -F = 0. The net force on 'A+B' is zero, since the only forces are internal.
These may help a bit: "[URL Forces
[/URL] & "[URL An Object and What Isn't?[/URL]
The forces cancel only if you include the reaction forces to any internal accelerations due to deformations (compression or expansion) within an object.
when you are referring to "internal forces", your subject is the system. thus, each internal force is exerted on the system. you can think of the system a mere point, and view the internal forces as the same as the external forces.
got it?
Yes! I got it now ...Thanks.
it is just a matter of what is your system...you have the total freedom to choose your system..if your system is a one particle , then you will have to take the internal forces only on it.. if the system is lot of particles then it is something like you are pushing your own hands against each other.. then you can't see any internal forces, they cancel out.. but as I first mentioned if it is a one hand , then you will have to take the 'force' by the other hand instead of taking the whole hand, because now your system is including only one hand...
Related to Internal forces on a system of particles
What is meant by internal forces on a system of particles?
Internal forces on a system of particles refer to the forces that act between the particles within the system. These forces are a result of interactions between the particles and can cause changes in the internal structure of the system.
What are some examples of internal forces on a system of particles?
Examples of internal forces on a system of particles include tension, compression, and shear forces. These forces can be seen in structures such as bridges, buildings, and machines.
How are internal forces different from external forces?
Internal forces act within a system of particles, while external forces act on the system from outside. External forces can cause the entire system to move, while internal forces only affect the individual particles within the system.
What is the significance of understanding internal forces on a system of particles?
Understanding internal forces on a system of particles is important in designing and analyzing structures. It helps in predicting the behavior and stability of a system, and also in determining the amount of force that each particle experiences.
How can internal forces on a system of particles be calculated?
Internal forces can be calculated using Newton's Third Law of Motion, which states that for every action, there is an equal and opposite reaction. By considering the forces acting on each particle and their interactions, the internal forces on a system can be determined.
  • Classical Physics
  • Classical Physics
