Internal heat exchanger on Evaporator
In summary, the COP of a single stage vapour compression refrigerator can be increased by using an internal heat exchanger on the evaporator. Further information is being requested on how to achieve this and the mathematical calculations involved in designing the heat exchanger and its relationship to the refrigerator's operating properties. Any knowledge or published material on this topic would be greatly appreciated.
recreated
50
You can read just bold, or all for further info. :D
The COP for a single stage vapour compression refrigerator increases with an increase in evaporating temperature. I would like to to know how it is achieved in reality with the use of an internal heat exch. on the evaporator.
Can anyone please send some further information on how to increase the evaporating temperature of a single stage vapour compression refrigeration system by the use of an internal heat exchanger?
In particular I would like to know the mathematical calculations used when designing to operating principles of the heat exch. in relation to the operating properties of the refrigerator.
Any knowledge on this would be extremely appreciated. Or any published material that I can read.
Thank you very much
Related to Internal heat exchanger on Evaporator
1. What is an internal heat exchanger on an evaporator?
An internal heat exchanger on an evaporator is a device that is used to transfer heat from one fluid to another within the evaporator. It is typically a coiled tube that allows for efficient heat transfer between the refrigerant and the air or water being cooled.
2. How does an internal heat exchanger improve the performance of an evaporator?
An internal heat exchanger helps to improve the performance of an evaporator by pre-cooling the refrigerant before it enters the main evaporating coil. This reduces the load on the compressor and increases the overall efficiency of the system.
3. What are the advantages of using an internal heat exchanger?
The main advantage of using an internal heat exchanger on an evaporator is improved energy efficiency. It also allows for a smaller evaporator coil, which can save space in the system. Additionally, it can help prevent compressor overheating by lowering the temperature of the refrigerant before it enters the compressor.
4. Are there any disadvantages of using an internal heat exchanger?
One potential disadvantage of using an internal heat exchanger is that it can add complexity to the system and may require additional maintenance. It can also increase the initial cost of the system. However, the energy savings and improved performance usually outweigh these potential drawbacks.
5. How do you know if your evaporator has an internal heat exchanger?
You can usually tell if an evaporator has an internal heat exchanger by looking for a separate coil or tube within the main evaporator coil. You can also consult the system's technical specifications or ask a certified HVAC technician to confirm if your evaporator has an internal heat exchanger.
  • General Engineering
  • Thermodynamics
  • Materials and Chemical Engineering
9K
