dancergirlie
- 200
A voltmeter whose resistance is 1000 ohms measures the voltage of a worn out 1.5V battery as .9V. What is the internal Resistance
In order to do this, I Solved for the Equiv Resistance of the circuit (leaving in the unknown Ri) by assuming they were two resistors in parallel. as:
Requiv=(1000+Ri)/(1000Ri)
Using ohms law I calculated the current through the circuit:
1.5=IRequiv
Plugging in my answer for Ri and simplifying I got:
I=(1500+1.5Ri)/1000Ri
Now assuming the resistors are in parallel, I would know that the current through each resistor is the same, meaning that I would get:
V=IRi
assuming the voltage drop across Ri as .6V (because 1.5-.9 is .6) I plugged that in and got:
.6=(1500+1.5Ri)/1000
However, when I solved for Ri, I got a negative number!
Help would be great!
Next, thinking that they were in parallel, the current through both resistors was the same, so
