Internal Resistance of a Car Battery
In summary: You might be able to start it with a higher voltage, but you would quickly destroy the battery. Is it really worth it?In summary, the battery has an internal resistance of .02 ohms.
Reliquo
An automobile battery has a terminal voltage of 12.8 V with no load. When the starting motor (which draws 90A) is running, the terminal voltage drops to 11.0 V. What is the internal resistance of the battery?
V= EMF- Ir
I think I'm just completely over thinking the problem and maybe missing something. In order to find EMF:
EMF= I(R+r) and in order to find this I need the R of the load in the circuit. This would be the Motor. The voltage drop is 1.8V so Ohm's Law would give V/I= (1.8)/(90A)=.02 Ohms, which seems way to low.
What am I missing here?
Hi Reliquo,
Welcome to Physics Forums!
Your result looks okay. The no-load terminal voltage of the battery will be its EMF. The drop in terminal voltage due to a given current draw will be the drop across its internal resistance, so ΔV/I is the correct way to proceed, as you did.
Reliquo said:
seems way to low.
It looks a bit lower than typical in the real world, but hey, you have to work with the numbers you are given.
gneill said:
Hi Reliquo,
So if the no-load terminal voltage of the battery is the EMF (12.8V) this would give:
V= EMF- Ir
11.0 V = 12.8 V - 90A(r)
-1.8 V= -90Ar
.02 = r (Internal resistance)
So is this correct then?
Likes CWatters
V= EMF- Ir
-1.8 V= -90Ar
Yes.
It actually looks very close to values I came up with about 10 years ago:
Code:
__measured__    calculated    notes
vdc    amps     R-internal
25.5     0       _n/a_       no load (and a guess)
22.6    96       0.030
22.5    92       0.033
22.2    97       0.034
22.4    95       0.032       average
I described the experiment briefly in at least three different threads. Here's one: https://www.physicsforums.com/threads/boiling-water-w-a-car-battery.870832/#post-5468458
The 25.5 vdc no load value is guessed, as I didn't document the initial value.
The two batteries I had in series were also mismatched. One was a marine deep cycle, and the other was a typical car "starting" battery.
If we accept my spreadsheets linear interpolation:
0.02 Ω is just about spot on.
Perhaps you are using a newer fancy battery.
No, just using numbers I found on the net.
You are correct. It seems low when a person at the electronics bench fiddling with milliamps all day imagines dumping 12 volts across a .1222 ohm load. The power supplies we use on a daily basis would fault out seeing .12ohms... but when you consider the electric motors efficiency, at perhaps 80%, you have .79kw being used as mechanical energy. Thats the equivalent of roughly 1 horsepower. Could a 1 horsepower pony motor crank your engine any better than that electric motor? Probably not. Its not a low resistance for the application, we are just not used to working with those current levels on a daily basis.
Consider what would happen if it was higher, say 1 Ohm. Could you start the car?
Related to Internal Resistance of a Car Battery
1. What is internal resistance of a car battery?
The internal resistance of a car battery refers to the resistance that occurs within the battery itself, which can affect its performance and overall lifespan. It is measured in ohms and is a result of the materials and design of the battery.
2. Why is internal resistance important in a car battery?
Internal resistance is important in a car battery because it can impact the battery's ability to deliver power to the car's electrical system. A higher internal resistance can result in a weaker and slower startup of the car, as well as a shorter lifespan of the battery.
3. How does internal resistance affect the performance of a car battery?
The internal resistance of a car battery can affect its performance by causing a voltage drop and limiting the amount of power that can be delivered to the car's electrical system. This can result in a slower startup, weaker electrical components, and a shorter lifespan of the battery.
4. What factors can contribute to increased internal resistance in a car battery?
There are several factors that can contribute to increased internal resistance in a car battery, including age, temperature, and repeated deep discharging. Other factors such as the type of materials used and the design of the battery can also play a role.
5. How can I measure the internal resistance of my car battery?
The most accurate way to measure the internal resistance of a car battery is with a specialized battery tester. However, you can also estimate the internal resistance by measuring the voltage drop across the battery while it is under load. A higher voltage drop indicates a higher internal resistance.
