CAH
- 48
The terminal voltage and current are measured as the resistance is decresed through a cell with emf and internal resistance. Graph of V (y axis) I (x axis) shows straight line decreasing gradient.
1. Explain why terminal pd decreases as the current increases.
is terminal pd the same as pd/voltage? I thought the pd across a resistor would always be the same provided your not adding resistors. However the mark scheme says:
mention of pd across internal resistance or loss in internal resistance or emf>V,
pd across internal resistance/loss volts increases with current or correct use of equation to demonstrate
So does the internal resistance increase with the current and so voltage is lost through wires?
Thanks![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks
