Internal stress in a wall at object impact
In summary: Your Name]In summary, the conversation discussed the process of calculating the internal stress in a wall after an object impacts it. The individual stresses were found to be equal to the impact force divided by the cross-sectional area of the wall. The type of stress will depend on the material properties of the wall and can be a combination of shear stress, compressive stress, and tensile stress. The total stress can be calculated using the principle of superposition by adding together the individual stresses. Good luck with your project!
Aragorn49
In the past months I've been working on a work calculating the behavior of a wall at an object impacting into it. I thought I have made it by knowing the impact force and the pressure it makes but then I realized that to fully complete my work I have to somehow calculate the internal stress in the wall. So to sumarize it, I know the impact force of the object hitting the wall and I also know the dimensions of both the wall and the object. What I'm trying to find out is what form of stress does occur inside the wall after object impact. Is it shear stress or maybe shear stress + another stress? How can I calculate this stress?
When studying about the individual stresses I found that there is always the equation of the stress being equal to F/A. I know F but I don't know what the A is. i know the dimensions of the wall but I don't know how to characterize what is the A and what isn't.
Well, I have studied the info I could find about the individual stresses but I still don't understand which stress to apply and what to consider the area (A) or cross section of the impact. I became pretty much confident that at least partially the stress is shear but there could be more stresses. I also don't know how to calculate a possible combined stress.
Thank you for reading my question
Aragorn49
Dear Aragorn49,
Thank you for sharing your question and progress on your project. It sounds like you are on the right track in considering the impact force and dimensions of both the wall and the object. However, to fully understand the internal stress in the wall, you will need to also take into account the material properties of the wall and how it responds to external forces.
In order to calculate the internal stress in the wall, you will need to use the equation you mentioned, where stress (σ) is equal to force (F) divided by the cross-sectional area (A). The cross-sectional area refers to the area of the wall that is being impacted by the object. This area will depend on the shape and dimensions of the object and the angle at which it impacts the wall. For example, if the object is a sphere and impacts the wall head-on, the cross-sectional area would be the area of a circle with the same diameter as the sphere.
In terms of the type of stress that occurs inside the wall, it will likely be a combination of different types of stress, including shear stress, compressive stress, and tensile stress. The specific type and magnitude of stress will depend on the material properties of the wall, such as its strength and elasticity.
To calculate the combined stress, you can use the principle of superposition, which states that the total stress at any point is equal to the sum of the individual stresses acting at that point. This means that you can calculate the individual stresses caused by the impact force and then add them together to get the total stress.
I hope this helps guide you in your research and calculations. Good luck with your project!
Related to Internal stress in a wall at object impact
What is internal stress in a wall at object impact?
Internal stress in a wall at object impact refers to the force exerted on the wall when it is hit by an external object. This force causes the materials in the wall to deform and can result in damage or failure of the wall.
What are the factors that contribute to internal stress in a wall at object impact?
The factors that contribute to internal stress in a wall at object impact include the speed and weight of the object, the angle at which it hits the wall, and the material and structural strength of the wall.
How does internal stress in a wall at object impact affect the structural integrity of the wall?
Internal stress in a wall at object impact can cause cracks, fractures, or even collapse of the wall, compromising its structural integrity. It can also weaken the overall stability of the building if the impact is severe enough.
What are some preventative measures that can be taken to reduce internal stress in a wall at object impact?
To reduce internal stress in a wall at object impact, it is important to use materials that are strong and durable, and to properly design and reinforce the wall structure. Adding protective barriers or padding can also help absorb the impact and minimize stress on the wall.
How can internal stress in a wall at object impact be measured or evaluated?
Internal stress in a wall at object impact can be measured using specialized instruments such as strain gauges or accelerometers. These devices can provide data on the force and deformation of the wall during impact, which can then be analyzed to assess the level of stress and potential damage.
  • Mechanical Engineering
