Interpret current density in plasma as material property?
In summary, the conversation discusses the propagation of an electromagnetic wave through a gas of free electrons, and shows that the index of refraction can be expressed in terms of the plasma frequency. The derivation uses Maxwell's fourth equation in vacuum and assumes a plane wave and a force on each electron. A question is then posed about the legitimacy of defining \epsilon_r and \mu_r in the context of calculating the refractive index, to which the response is that the derivation appears to be legitimate and can be extended further.
lampCable
An electromagnetic wave propagates through a gas of N free electrons per unit volume. Neglecting damping, show that the index of refraction is given by
[tex]
n^2 = 1 - \frac{\omega_P^2}{\omega^2},
[/tex]
where the plasma frequency
[tex]
\omega_P = \sqrt{\frac{Ne^2}{\epsilon_0m_e}}.\quad(1)
[/tex]
We assume that the incident wave is a plane wave, and that on each electron [itex]F = qE[/itex].
Maxwell's fourth equation in vacuum where there exist charges and current:
[tex]
\nabla\times\textbf{B} = \mu_0\textbf{J} + \mu_0\epsilon_0\frac{\partial\textbf{E}}{\partial t}.
[/tex]
Integrating Newtons second law and neglecting any source velocity we get
[tex]
\textbf{v} = \frac{iq}{m\omega}\textbf{E}_0e^{i(kz-\omega t)}.
[/tex]
The current density, then, is
[tex]
\textbf{J} = Nq\textbf{v} = -\frac{Nq^2}{m\omega^2}\frac{\partial\textbf{E}}{\partial t}.\quad(2)
[/tex]
Using now Maxwell's fourth equation in vacuum together with (1) and (2) we get
[tex]
\nabla\times\textbf{B} = \mu_0\epsilon_0\bigg(1-\frac{\omega_P^2}{\omega^2}\bigg)\frac{\partial\textbf{E}}{\partial t}.
[/tex]
Question: Is it legit to here define [tex]\epsilon_r\mu_r = 1 - \frac{\omega_p^2}{\omega^2}[/tex] for the purpose of calculating the refractive index?
My argument for this is as follows. Since
[tex]
n = \sqrt{\epsilon_r\mu_r}
[/tex]
it doesn't matter really (for the purpose of determining the refractive index) how [itex]\epsilon_r[/itex] and [itex]\mu_r[/itex] are chosen per se, so long as their product satisfy the above definition. In this sense it is then possible to convert a case where we have a region with current density, to one where we simply have a material with [itex]\epsilon_r\epsilon_r\neq1[/itex] instead. But since we are free to choose [itex]\epsilon_r[/itex] and [itex]\mu_r[/itex], the analogy could not go further to where the two are used separately.
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
Your derivation looks quite legitimate. The next step in deriving the E-M wave (at least the ## B ## part) is to take the curl of both sides of your equation. With a vector identity ## \nabla \times \nabla \times B=\nabla (\nabla \cdot B)-\nabla^2 B ##, and using Faraday's law on the other side, you have the wave equation for ## B ## and the wave velocity is determined precisely by what you have already presented. editing... Alternatively you could begin with Faraday's law ## \nabla \times E=-dB/dt ## and again take the curl of both sides of the equation and proceed in a similar fashion to get the wave equation for the electric field ## E ##.
Related to Interpret current density in plasma as material property?
1. What is current density in plasma?
Current density in plasma refers to the amount of electric current flowing through a unit area of a plasma. It is a measure of the strength of the electric current and is typically expressed in units of amperes per square meter.
2. How is current density in plasma measured?
Current density in plasma can be measured using various techniques such as Langmuir probes, magnetic probes, and microwave diagnostics. These techniques involve placing a probe or sensor within the plasma to measure the current flowing through a specific area.
3. What factors affect the current density in plasma?
The current density in plasma can be affected by several factors, including the plasma temperature, density, and composition. Additionally, the presence of external magnetic fields, electric fields, and collisions between particles can also influence the current density in plasma.
4. How does current density in plasma relate to material properties?
Current density in plasma is closely related to the material properties of the plasma, such as its electrical conductivity. The higher the current density, the more conductive the plasma is, and vice versa. This relationship can provide valuable insights into the behavior of plasma as a material.
5. Why is it important to interpret current density in plasma as a material property?
Interpreting current density in plasma as a material property allows scientists to better understand the behavior of plasma and its potential applications. By studying the relationship between current density and material properties, researchers can develop more efficient plasma-based technologies for various industries, such as energy production and materials processing.
  • Electromagnetism
