Interpretation of a memristor's hysterisis loop
The discussion focuses on the interpretation of a memristor's hysteresis loop, highlighting key observations related to frequency effects. As frequency increases, the area of the hysteresis loop decreases, and the graph tilts towards the x-axis, suggesting that memristance decreases with higher frequencies. A slight deformity in the curve at higher voltage-current values is attributed to the dominance of tunneling effects, as supported by relevant literature. The conversation also touches on the limitations of the linear-drift model in accounting for these phenomena. Overall, the analysis seeks to deepen the understanding of memristor behavior in relation to frequency and voltage effects.
madaari
Hi forums,
Following is the hysteresis loop of a standard memristor:
Please note that, the red one is for lowest frequency and black for highest frequency.
From the graph, one can take the following observations:
1> As frequency increases, area of graph decreases
2> With increase in frequency, graph tends to tilt more towards x axis
3> Slight deformity of the red curve at higher VI values.
I tried interpreting these observations, keeping in mind memristors Piecewise linear model(Is that a correct assumption?).
If second observation is correct:- Memristance decreases with increase in frequency and at frequency tending to infinity, it acts like a constant value resistance whose value should be Minimum possible value of memristance. Right?
Also, I need a bit explanation for observation number 3(about deformity). I'm unable to figure out it's reason.
Thanks,
[moderator edited out the OP's name and cross posting info.]
Yup, I had a look at it. I'm mostly comfortable with the physics, just had few questions about shape of hysteresis loop, the ones that i mentioned in my earlier post i couldn't correlate that to theory. Mainly, these two:
What's the reason of this tilt in 2? and deformity in 3?
Ok, thanks. Skin effect could be a reason, i'll dig deeper into it.
But it's only skin deep :smile:
Likes anorlunda
Ok, got one more strong argument for (3) observation i.e slight deformity at higher i-v values. In this paper:
M. D. Pickett, D. B. Strukov, J. L. Borghetti, J. J. Yang, G. S. Snider, D. R. Stewart, and R. S. Williams, “Switching Dynamics in Titanium Dioxide Memristive Devices,” J. Appl. Phys., vol. 106, p. 074508, 2009.
They explained the dominance of tunneling effect at higher voltages, which could lead to the observed slight deformity in memristor's i-v curve.
I guess that these loops are calculated on base of the "memristor" model presented by Strukov et al. in their paper "The missing memristor found". If this is the case, there are no more physics in than a simple linear-drift model for mobile dopants.
  • · Replies 22 ·
  • · Replies 21 ·
