Interpretation of the field operator
In summary, the conversation discusses the interpretation of field operators in Quantum Field Theory and their usefulness in constructing relativistically invariant Hamiltonians for describing physical processes with changing number of particles. Quantum fields are primarily used as a mathematical tool, and their physical counterparts should not be sought after. The amplitude of a scattering process is related to the kernel of the time evolution operator and can be computed using n-point correlation functions.
martin_blckrs
43
Hi,
I've just finished a 2 semester course on Quantum Mechanics and I am now eager to learn some Quantum Field Theory. I started to read some books on my own, but I have some problems understanding a few concepts.
My main problem is this:
In the Canonical Quantization procedure, we take some classical field and make the (infinite number of) positions and momenta into operators and postulate the commutation relations between them. Now if we, for example, take the real scalar field, we obtain the field operators [tex]\Phi(x)[/tex]. Since the field is real, these operators are all Hermitian and thus should correspond to an observable (by QM). The questions are: How should I interpret this observable? What does the expactation value of this operator tell me? Can I view the operator as a creation operator of a particle with a given position (in space-time)?
I will tell you my opinion, which is not widely shared by others (unfortunately): there is no any physical interpretation for fields operators, they are just formal mathematical objects.
The main purpose of quantum field theory is to provide description of physical processes, in which the number of particles can change. So, in contrast to ordinary quantum mechanics, QFT should have interaction Hamiltonians, which do not commute with particle number operators. In principle, you can construct such Hamiltonians without using quantum fields, e.g., as abstract matrices acting in the Fock space. Quantum fields and creation/annihilation operators simply provide a convenient mathematical tool for writing such interaction operators in a compact form. Quantum fields are particular linear combinations of creation/annihilation operators, which have simple Lorentz transformation properties. As discussed in Weinberg's textbook, these properties guarantee that you can build relativistically invariant Hamiltonians simply as products of few field operators. This is the only reason why quantum fields are useful. After you constructed the interacting Hamiltonian of your theory (as a product of fields) and proved its relativistic invariance, you don't need quantum fields anymore. You can do quantum mechanics with this Hamiltonian in a usual way and obtain, for example, amplitudes for transitions between asymptotic states with different number of particles (the S-matrix elements), or energies of bound states.
In conclusion, quantum fields are just formal mathematical symbols that allow one to simplify the notation considerably. Do not try to find physical counterparts to quantum fields. The more you try, the more confused you'll be.
OK, but then another question: Why do we interpret the vacuum expactation value as the amplitude of the scattering process?
In single particle quantum mechanics the amplitude of a scattering process is the kernel of the time evolution operator i.e. the Green's function for the operator exp(-i t H). To see the connection between Green's functions and expectation values you might want to read about the general concept of a n-point correlation function, which are ultimately the solutions that field theorists would like to compute.
This article does not seem too well written, but it might get you started:
http://en.wikipedia.org/wiki/Green's_function_(many-body_theory )
Probably the best thing to keep in mind while reading on QFT is that in the end, it's all about the correlation functions. In the end, everything is aimed at determining these fellas.
FAQ: Interpretation of the field operator
What is a field operator?
A field operator is a mathematical operator used in quantum field theory to describe the behavior of fields, which are physical quantities that exist at every point in space and time.
How is the field operator interpreted in quantum mechanics?
In quantum mechanics, the field operator is interpreted as a way to describe the quantum state of a system. It is a fundamental quantity that allows us to make predictions about the behavior of particles and their interactions.
What is the difference between a field operator and a wave function?
A field operator is a mathematical object that describes the quantum state of a system, while a wave function is a mathematical representation of the probability amplitude of a particle's position and momentum.
How is the field operator related to observables?
The field operator is related to observables through the process of measurement. The expectation value of an observable can be calculated using the field operator, which represents the quantum state of the system.
What are the implications of the interpretation of the field operator?
The interpretation of the field operator has significant implications for our understanding of the quantum world. It allows us to make predictions about the behavior of particles and their interactions, and has played a crucial role in the development of quantum field theory and modern physics.
