Interpretation: Solution to a set of Linear Equations
In summary, every linear equation corresponds to a set of vectors in a vector space, and the usual considerations (e.g. finding a point, determining degrees of freedom) apply. If the system is completely satisfied, you have a point in the vector space. If you have one variable less than what you need, there's a degree of freedom, the variable is free to assume any values.
chaoseverlasting
1,050
Hi,
While solving a system of linear equations, there are three possible cases - unique / infinite / no solutions - to the system.
One geometric interpretation is when one looks at a set of planes intersecting at one / many / no points respectively, for each of the above cases.
While going through what constitutes a vector space & how to check if a set of vectors belongs to a vector space (Sec. 7.4, q 27-36, p.302, Erwin Kreyzsig 9th Ed.), it seemed to me that the tests are similar to the Gauss Elimination method of checking for a single / many / no solutions via the rank of the augmented / coefficient matrices.
Is it possible to interpret the solutions (one, many, none) to a system of linear equations in terms of vector spaces?
I.e. if there is only one solution, the ranks of the augmented & coefficient matrices are equal - this means that we have identified a fundamental vector space for that system of equations.
If there are multiple solutions (infinitely many) to the system, then there is a more fundamental vector space for that system of equations and the augmented matrix / coeffiecient matrix vector space is a super set of that fundamental vector space - thus leading to infinitely many solutions.
For the no solution case, the vector spaces are dissimilar and unrelated, thus no solutions exist.
Apologies if the explanations are unclear - I'm still trying to understand the material better.
TIA for any insights / inputs.
Replace "vector spaces" by "sets of vectors" and it works. Every linear equation corresponds to a set of vectors satisfying this equation. If there is no solution, the intersection is empty. If there is one, the intersection has a single vector.. If there is an infinite set of solutions, you have a line/plane/... in the vector space as set of solutions.
Systems of linear equations are linear mappings, which are, in turn, a special class of functions. It is thus isomorphic to a function of n variables in, say, an Euclidean space (which we can visualize easier), and the usual considerations apply. If the system is completely satisfied, you have a point in this space. If you have one variable less than what you'd need, there's a degree of freedom, the variable is free to assume any values, in the same way a line would in an Euclidean space. And so on...
Related to Interpretation: Solution to a set of Linear Equations
1. What is the definition of "Interpretation: Solution to a set of Linear Equations"?
Interpretation: Solution to a set of Linear Equations refers to the process of finding the values of the unknown variables in a system of linear equations that satisfy all the equations in the system.
2. Why is finding the solution to a set of linear equations important?
Finding the solution to a set of linear equations is important because it allows us to solve real-world problems by representing them in mathematical equations and finding the values of the variables that satisfy all the conditions.
3. What are the methods for solving a set of linear equations?
The most common methods for solving a set of linear equations are substitution, elimination, and graphing. These methods involve manipulating the equations to either eliminate or isolate a variable, and solving for the remaining variables.
4. Can a set of linear equations have more than one solution?
Yes, a set of linear equations can have infinitely many solutions or no solution at all. This depends on the relationship between the equations and the number of variables in the system.
5. How can we check if a set of linear equations has a solution?
A set of linear equations has a solution if the equations are consistent, meaning they can be satisfied by the same set of values for the variables. This can be checked by substituting the values into the equations and seeing if they are all true.
  • Linear and Abstract Algebra
