Interpreting a double integral as volume
In summary, the function F(x,y) = 4x^2y^3 over the disk x^2 + y^2 =1 is zero due to its odd symmetry in terms of y. This means that when integrating over any line parallel to the y-axis with symmetric limits, the resulting integral will be zero, making the entire double integral (or triple integral) zero. This concept can be extended to other odd functions, such as G(x,y) = y^3.
naggy
60
The function F(x,y) = 4x^2y^3 over the disk x^2 + y^2 =1 is supposed to be zero over the disk. I'm wondering how you can see it?
I cannot see this or imagine it in 3D. Is it because the function is odd in terms of y?
F(x,-y) = -F(x,y) ? independent of wheher x is positive or negative?
Because functions like G(x,y) = y^3 is obviously odd and so the double integral would be zero over the same disk, but I have an extra x^2 term. How is one supposed to think this?
The fact that it's even with respect to the x variable just means that it is symetrical about x = 0 along any line parallel to the x-axis, but it is odd with respect to the y variable so the canceling out of the area occurs along the y direction only...
So the integral (volume) is not zero?
It is zero. Have you calculated double integrals yet? If you integrate over any line parallel to the y-axis using symmetric limits, so x stays constant, you see that the integral is zero:
[tex] \int_{-1}^{1}4x^2 y^3 dy[/tex]
(Note that x is treated as a constant here, since it doesn't vary along a line parallel to the y-axis)
[tex] 4x^2\int_{-1}^{1}y^3 dy[/tex]
[tex] 4x^2 \left[y^4/4\right]_{-1}^{1} [/tex]
[tex] 4x^2 [1/4-1/4] = 4x^2 . 0 = 0 [/tex]
i.e. once the function is odd with respect to one variable that is enough for the whole thing to be zero (once your limits symmetric) because once that intergral is zero, the whole double integral (or triple integral or whatever) must be zero. Does this makes sense?
Yup. thx
Related to Interpreting a double integral as volume
1. What is a double integral?
A double integral is a mathematical tool used to calculate the area under a surface in two-dimensional space. It involves evaluating a function over a region of the xy-plane.
2. How is a double integral related to volume?
A double integral can also be interpreted as the volume under a three-dimensional surface. By integrating a function over a region in the xy-plane, we can find the volume of the solid that is created by the surface and the region.
3. What is the process for interpreting a double integral as volume?
To interpret a double integral as volume, we first identify the function and the region over which we want to calculate the volume. Then, we set up the double integral by integrating the function with respect to both x and y over the given region. Finally, we evaluate the integral to find the volume.
4. What are some real-world applications of interpreting a double integral as volume?
Interpreting a double integral as volume has many practical applications in fields such as engineering, physics, and economics. For example, it can be used to calculate the volume of a three-dimensional object, the amount of fluid in a container, or the value of a stock portfolio over time.
5. Are there any limitations to interpreting a double integral as volume?
One limitation is that this method can only be used for calculating the volume of solids with a well-defined boundary. Additionally, it may not be suitable for objects with complicated shapes or for objects in non-Euclidean spaces.
