MHB Interpreting Constant A & Deriving k in Air Pressure Decay
The discussion revolves around understanding the exponential decay of air pressure with altitude, modeled by the equation p(h) = A e^(kh). The constant A represents the air pressure at sea level, while the challenge lies in deriving the constant k, which is linked to the decay rate of 0.4 percent for every 30 meters. To find k, participants are advised to substitute the pressure equation into the decay relationship, leading to the equation p(h+30) = 0.996 p(h). The solution involves recognizing the properties of exponentiation and logarithms, particularly that k can be derived as k = ln(0.996) / 30.
fuzz95
hey guys! I'm really confused as to what this question is trying to ask me!
can someone help me out :)
Air pressure decays approximately exponentially at about 0.4 per cent for each rise of 30 metres above sea level. If we let p = p(h) denote air pressure (measured in some appropriate units) at h metres above sea level, then we can model this phenomenon using the equation: p = p(h) = Aekh for some appropriate constants A and k.
Give an interpretation for the constant A. (We never need to know the actual numerical value of A to do the rest of this exercise.)
?and how do i derive this k = ln(0.996) / 30 ??thanks!
Mathematics news on Phys.org
Hi, and welcome to the forum!
This must be $p(h)=Ae^{kh}$. In plain text, it is customary to write exponentiation using ^, and don't forget the order of operations: exponentiation is done before multiplication. Therefore, in plain text p(h) can be written as A*e^(kh).
Hint: At what height the pressure is $A$?
The statement "Air pressure decays approximately exponentially at about 0.4 per cent for each rise of 30 metres above sea level" amounts to
p(h+30)=0.996p(h).
Substitute the definition of $p$ and see if you can solve this equation for $k$.
okay so i was able to do the first part!
however still have no idea how to go about doing the second half??!
p(h+30)=0.996p(h).
Well, let me do this for you. Substituting $p(h)=Ae^{kh}$ into the equation above gives
Ae^{k(h+30)}=0.996Ae^{kh}.
Can you solve it for $k$? If not, do you know basic properties of exponeniation? Do you know that $\ln(x)$ is the inverse of $e^x$? Have you seen any exponential equations solved? Have you solved any yourself? You may need to do some preparatory work.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
