Interpreting Seidel Aberration coefficients
In summary, the conversation discusses a discrepancy between the Seidel aberration values and the ray-tracing results in a simple system model. Adding an achromatic pair causes the Seidel coefficients for field curvature to increase at surface IM2, but the ray tracing shows a smaller field curvature. This could be due to factors such as the system not being designed to be telecentric, other aberrations not accounted for in the Seidel coefficients, and the materials used for the lenses.
NazRB
I am trying to model a simple system, but the ray-tracing does not seem to be consistent with the analysis of the system in terms of Seidel aberration values. Here's the system layout:
When the system contains only the Eye model and the OL lens, it can be referred from the Seidel diagram that the SUM of the aberrations at IM1 for field curvature and distortion are +9um and -19um respectively. It can seen that the peripheral rays' focus is lagging the paraxial focus - thus, the image is not flat:
Then, when I add the achromatic pairs P1 and P2, the new image is at surface Im2, the new SUM of Seidel coefficients for filed curvature and distortion are +13 and -20 respectively:
Thus, I would expect the IM2 surface to be even more curved, however, looking at the IM2 plane ray diagram, the peripheral points seem to focus much closer to the paraxial image plane - thus, the field curvature seems to be much smaller. So, the question is why the Seidel coefficients for filed curvature for IM2 are larger than for IM1, but the apparent ray-tracing shows smaller filed curvature in IM2 (which is expected to be larger than in IM1)?
A:The Seidel coefficients are based on a paraxial approximation. The ray tracing, on the other hand, shows what is actually happening in the system. The difference between these two results could be caused by different factors. If the system is not designed to be telecentric, the entrance pupil shape and size can affect the field curvature. Also, since the Seidel coefficients are approximations, they can also be affected by other aberrations that are not included in the approximation. Finally, the materials used for the lenses can also affect the actual ray tracing results compared to the Seidel coefficients.
Related to Interpreting Seidel Aberration coefficients
1. What are Seidel aberration coefficients?
Seidel aberration coefficients are a set of numbers that describe the effects of optical aberrations on an optical system. These coefficients are derived from the Seidel aberration theory, which is used to analyze and correct for aberrations in optical systems.
2. How are Seidel aberration coefficients calculated?
Seidel aberration coefficients are calculated by analyzing the wavefront of an optical system. The wavefront is a representation of the phase and amplitude of light as it travels through the system. By analyzing the wavefront, the coefficients can be determined, which describe the amount and type of aberrations present in the system.
3. What do the Seidel aberration coefficients tell us?
The Seidel aberration coefficients provide information about the aberrations present in an optical system, including the type and amount of aberration. This information is useful for designing and improving optical systems, as well as for diagnosing and correcting aberrations in existing systems.
4. How are Seidel aberration coefficients used in optical design?
Seidel aberration coefficients are used in optical design to identify and correct for aberrations in the system. By analyzing the coefficients, optical designers can make adjustments to the system, such as changing the shape of lenses or adding corrective elements, to reduce or eliminate aberrations and improve the overall performance of the system.
5. Are Seidel aberration coefficients the only way to analyze aberrations in optical systems?
No, there are other methods for analyzing aberrations in optical systems, such as Zernike polynomials and ray tracing. However, Seidel aberration coefficients are a commonly used and useful tool for understanding and correcting aberrations in optical systems.
11K
  • Other Physics Topics
