Interpreting SM Lagrangian "differential particle" terms
In summary: This is why Feynman diagrams are usually drawn with arrows poking out of interactions, there is a directionality and magnitude to the interaction. In summary, the Standard Model Lagrangian contains terms involving derivatives of fields, which represent the rate of change of those fields. In the momentum representation, these derivatives become the 4-momenta corresponding to the fields in Feynman diagrams. These terms give an energy penalty to large fluctuations in space and time, similar to the action for a one-dimensional string. In a particle picture, the strength of interaction between particles depends on their four momenta in addition to a fixed constant.
Seirios
The Standard Model Lagrangian contains terms like these:
##-\partial_\mu \phi^+ \partial_\mu\phi^-##
##-\frac{1}{2}\partial_\nu Z^0_\mu\partial_\nu Z^0_\mu##
##-igc_w\partial_\nu Z^0(W^+_\mu W^-_\nu-W^+_\nu W^-_\mu)##
How should one interpret the "derivative particle fields" like ##\partial_\mu\phi^+## physically? What are they or what do they represent?
Or, more generally, how should one interpret the differentiation, especially when applied to what represents physical objects?
It is not differential particles. The standard model is a quantum field theory and contains fields. The derivatives are the derivatives of those fields.
My mistake. But does that mean the fields interact with their own rates of change or something? Is there an easy way to make physical sense of it?
In the momentum representation, the derivatives become the 4-momenta corresponding to the fields in the Feynman diagrams.
Likes DarMM and vanhees71
Basically yes, if you want a way to think about it then imagine that whatever field your working with is unbound, and so has some plane-like wavefunction. Then these derivatives are basically creating interaction terms that have a proportionality to the momentum of the field.
Since it plane-like, (so like e^(x.p)) itll give you the momentum times the field itself. That way you still have creation/annihilation operators in the field, but get the momentum out of it. All of these operations will happen once you start integrating over the terms.
Those terms give an energy penalty to large fluctuations in space and time. Compare them to the action for a one-dimensional string:
\mathcal{S} = \int dt \, dx \left[ \frac{\rho}{2} \left(\frac{\partial u(x,t)}{\partial t}\right)^2 - \frac{T}{2} \left(\frac{\partial u(x,t)}{\partial x}\right)^2 \right]
where ##u(x,t)## is the amplitude, ##\rho## is the density per unit length, and ##T## is the string tension. The Euler-Lagrange equation for this action is just the wave equation, and the two terms (which are combined in a relativistic notation in your post) correspond to kinetic and potential energy respectively. Various complications occur from quantizing these theories, but the idea that large variations in space and time cost more energy is still true.
Likes Orodruin
Exactly, in a particle picture how strongly the particles couple to each other/the vertex for their interaction depends not just on a fixed constant like ##e## the electric charge, but also on their four momenta.
Related to Interpreting SM Lagrangian "differential particle" terms
1. What is a "differential particle" in the context of the SM Lagrangian?
A "differential particle" in the SM Lagrangian refers to a particle that is described by a differential equation, rather than a discrete equation. This means that the particle's behavior is described in terms of continuous variables, such as position and time, rather than discrete values.
2. How do "differential particle" terms in the SM Lagrangian contribute to our understanding of particle physics?
The "differential particle" terms in the SM Lagrangian allow us to mathematically model the behavior of particles in the Standard Model of particle physics. By understanding how these particles interact with each other and their environment, we can gain insights into the fundamental forces and building blocks of the universe.
3. Can you provide an example of a "differential particle" term in the SM Lagrangian?
One example of a "differential particle" term in the SM Lagrangian is the term that describes the behavior of the Higgs boson. This term includes a differential equation that describes how the Higgs field interacts with other particles and gives them mass.
4. How do "differential particle" terms in the SM Lagrangian relate to experimental observations?
The "differential particle" terms in the SM Lagrangian can be used to make predictions about the behavior of particles that can then be tested through experiments. By comparing these predictions to experimental results, we can validate the accuracy of the SM Lagrangian and gain a better understanding of the fundamental particles and forces in our universe.
5. Are there any limitations or challenges in interpreting "differential particle" terms in the SM Lagrangian?
One challenge in interpreting "differential particle" terms in the SM Lagrangian is the complexity of the equations and the need for advanced mathematical techniques to solve them. Additionally, the SM Lagrangian may not fully capture all aspects of particle behavior, and further research and experiments are needed to continue refining our understanding of the universe.
  • Quantum Physics
  • Other Physics Topics
