A Interpreting the energy density of QFT vacuum states
math-physicist
I am reading Peskin-Schroeder's QFT text, and there on pg. 98 Equation (4.56) they derive the expression for the vacuum energy density (relative to the zero of energy set by ##H_0|0\rangle = 0##):
$$ \frac{E_0}{\rm{Volume}} = \frac{i\,\sum\text{(all disconnected pieces)}}{(2\pi)^4\,\delta^4(0)}\ . $$
My questions are:
  • What do they mean by "relative to the zero of energy set by ##H_0|0\rangle = 0##" ?
  • The right side of the above expression has a delta function evaluated at 0. Doesn't that imply that the right side is essentially negligible/zero? Then how does one interpret this equation? The vacuum has zero energy?
  • How does one derive Equation (4.56) starting from Equation (4.55) which states:
    $$ e^{\sum V_i}\propto e^{-2iE_0T}\ ? $$
My questions are:
A Hamiltonian is defined only up to a constant energy shift. The condition fixes this constant by requiring that that the ground state (vacuum) has energy zero.
No. The delta function is in the denominator! This is sloppy notation, What is meant is that after multiplication with the denominator, reinterpreting the formula in a distributional sense, and integration over a test function, the equation is valid in perturbation theory.
This is a well-known combinatorial results for generating functionals, relating the moment generating function and the cumulant generating function. See https://en.wikipedia.org/wiki/Moment-generating_function#Relation_to_other_functions
Likes math-physicist
@A. Neumaier , Thank you for your answer. Your answer to my first two questions makes sense. but in answer to my third question, you said:
I think you misinterpreted what I was asking. I meant to ask why does that proportionality imply the energy density relation? I.e.,
$$ e^{\sum V_i}\propto e^{-2iE_0T} \stackrel{\implies}{\rm{(Why??)}} \frac{E_0}{\rm{Volume}} = \frac{i\,\sum\text{(all disconnected pieces)}}{(2\pi)^4\,\delta^4(0)}\ . $$
Could you please at least sketch the steps of this derivation? TIA.
One takes the logarithm in the left relation and applies the combinatorial result I stated to the expansion of the left hand side, which is the moment generating function.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
