joemomma
- 1
Two mine cars of equal mass are connected by a rope which is initially slack. Car A is imparted a velocity of 4m/s with car B initially at rest. When the slack is taken up the rope suffers a tension impact that imparts a velocity to car B and reduces the velocity of car A.
a. If 40% of the kinetic energy of car A is lost during the impact calculate the velocity imparted to car B.
b. Following the initial impact car B overtakes car A and the two are coupled together. Calculate their final common velocity.
The definition of kinetic energy:
KE = [itex]\frac{1}{2}[/itex]*m*[itex]V^{2}[/itex]
Momentum impulse equation:
[itex]m_{1}[/itex]*[itex]v_{1}[/itex]+[itex]\int\sum F[/itex] = [itex]m_{2}[/itex]*[itex]v_{2}[/itex]
part B is easy, you just assume both carts are a system so there is no outside impulse.
[itex]m_{B}[/itex]*0+[itex]m_{A}[/itex]*4=[itex]m_{A}[/itex]*v+[itex]m_{B}[/itex]*v
[itex]m_{A}[/itex] = [itex]m_{B}[/itex]
Since they are both the same mass they each end up going 2 m/s.
Part A is confusing me. The problem states that 40 % of the kinetic energy of cart A is lost during the impact. That means that 60 % of the kinetic energy is remaining. I should be able to use the definition of kinetic energy to solve for the velocity of cart A after the impact by saying:
0.6*[itex]KE_{A1}[/itex]=[itex]KE_{A2}[/itex]
After that I'm not really sure what to do. I presume the change in kinetic energy can be seen as an impulse, where
M*[itex]V_{2}[/itex]-M*[itex]V_{1}[/itex] = [itex]\int\sum F[/itex]
With M being the mass of one cart, V1 being the initial speed of cart A (4 m/s), and V2 being the speed of cart A after the impact. Then that impulse would be applied to cart 2 with an initial speed of 0 m/s.
The problem is that when I take this method I solve for a post-impact speed of cart A being 3.1 m/s and cart B being 0.9 m/s. Obviously this can't be right since the stationary cart is supposed to be overtaking the cart that was originally moving.
I hope that made sense. I'm not really used to this LATEX formatting. If I can elaborate on anything please let me know.
