Intersecting lines,circles,and parabolas
  • Thread starter Sumaya
In summary, the homework statement is that to find the points in which the graphs intersect, you need to solve for x and y. You can do this by replacing x^2+ y^2= 1 with y+ y^2= 1, or by solving for x and y using the quadratic equation. Once you have solved for x and y, you can use them to find the points of intersection.
Sumaya
29
y=2x, x^2+y^2=1
the center point of the circle is (0,0)
and the radius = 1
and i collect some points to draw the line equation
(-1,-2) (0,0) (1,2) (2,4) etc ..
but i don't know how to get the intersect points ..
and also for the parabola equation ... are they have same way to know the intersect points ...
is there a rule or what ??
please explain to me in simple english words..
thanx a lot ...
Just solve for x and y. Plug y = 2x into
x2+y2=1
to get
x2+(2x)2=1
Solve for x (you should get two solutions), and plug both into
y = 2x
to get the corresponding solutions for y.
The 2nd equation is an equation of a circle, not a parabola.
In simple English (nicht Deutsch, warum?), don't worry about the geometry, solve the equations!
If the problem were to find the intersection of [itex]x^2+ y^2= 1[/itex] and [itex]y= x^2[/itex], the first is a circle and the second a parabola. That's nice to know (it tells us we can expect to find two points of intersection) but not necessary to the solution. Since [itex]y= x^2[/itex] we can replace [itex]x^2[/itex] by y in the first equation: [itex]y+ y^2= 1[/itex] or [itex]y^2+ y- 1= 0[/itex]. That's a quadratic equation and we can either complete the square or use the quadratic formula to solve for y. Once we have found y, x is a square root.
(The quadratic equation has two roots, of course, and you might think that since each has two roots, there would be 4 (x, y) combinations. But one of the (real) roots to the quadratic is negative. That gives only imaginary roots and coordinates of points in a graph must be real. Only y> 0 gives the two points of intersection.)
x2+y2=1
to get
x2+(2x)2=1
y = 2x
thanx a lot ...
you are right ..
and i undestand how to solve the equation ...
thanx a lot ..
Related to Intersecting lines,circles,and parabolas
1. What is an intersecting line?
An intersecting line is a line that crosses or cuts through another line at a specific point, creating an intersection.
2. How many points of intersection can two lines have?
Two lines can have one point of intersection, no points of intersection if they are parallel, or an infinite number of points if they are the same line.
3. What is the equation for a circle?
The equation for a circle is (x - h)^2 + (y - k)^2 = r^2, where (h, k) is the center of the circle and r is the radius.
4. Can a line and a circle intersect at more than one point?
Yes, a line can intersect a circle at two points, creating a chord. However, if the line is tangent to the circle, it will only intersect at one point.
5. What is the difference between a parabola and a circle?
A parabola is a curved shape with one axis of symmetry, while a circle is a curved shape with infinite axes of symmetry. Additionally, the equation for a parabola is y = ax^2 + bx + c, while the equation for a circle is (x - h)^2 + (y - k)^2 = r^2.
