Intersection of a circle and a parabola
In summary, the intersection of a circle and a parabola refers to the points where the two curves intersect or overlap each other. A circle and a parabola can have up to two points of intersection, which can be found by solving their equations simultaneously. They cannot intersect at an infinite number of points and there are certain scenarios where they may not intersect at all.
rajeshmarndi
319
We have a circle (x^2 + y^2=2) and a parabola (x^2=y).
We put x^2 = y in the circle equation and we get y^+y-2=0. We get two values of y as y=1 and y=-2.
Y=1 gives us two intersection point i.e (1,1) and (-1,1). But y=-2 neither it lie on the circle nor on the parabola. The discriminant of the quadratic equation y^+y-2=0 is positive but yet, why do we get the other solution(y=-2) in complex form?
Thank you.
[Moderator's note: Moved from a technical forum and thus no template.]
There there are in fact (complex) solutions with ##y=-2##. The points ##(i\sqrt{2},-2)## and ##(-i\sqrt{2},-2)## lie on both curves.
There's nothing unusual about having some real and some non-real solutions. For a simpler example, the function ##y=x(x^2+1)## has one real root, and two non-real roots.
That mean, even if the discriminant of the quadratic equation is positive, we can still get solution in complex form.
I doubt very much that complex solutions are relevant in this problem.
The given equations are ##x^2 + y^2 = 2## and ##y = x^2##. From the second equation, y must be nonnegative since it's the square of a real number. The equation obtained after replacing ##x^2## in the circle equation resulted in the quadratic equation ##y^2 + y - 2 = 0## whose solutions were y = 1 and y = -2.
Since y =-2 is not a solution of the equation ##y = x^2##, there won't be any points common to both curves with this y-value.
They are not relevant to the problem to be solved, but they are relevant to the OP's question: where do these complex solutions come from?
If we allow complex values of x then we can visualise them by plotting the imaginary part on the z axis. For the circle, we get a rectangular hyperbola in the YZ plane, meeting the circle at (0, ±√2, 0). For the parabola, we get a parabola in the negative y half of the YZ plane, meeting the original parabola orthogonally at the origin.
The additional solutions are where these curves intersect.
When you replaced x^2 by y you got a quadratic equation for y with two real roots. f(y) =y^2+y-2 is a parabola and it intersects the y-axis in two points. This problem is different from the original one. In the original problem, negative value was not allowed for y, as y was the square of a real number. So y=-2 had to be discarded.
If you replace y by x^2 you got a fourth-order equation in x: x^4+x^2-2=0. That equation has two real roots and two complex (imaginary) ones
When you give the solution of the original problem you have two check which roots are relevant you will discard the imaginary x values.
Likes Delta2
Related to Intersection of a circle and a parabola
1. What is the intersection of a circle and a parabola?
The intersection of a circle and a parabola is the point or points where the two curves intersect on a graph. This can be found by solving the equations of the circle and parabola simultaneously.
2. How many points of intersection can a circle and a parabola have?
A circle and a parabola can have a maximum of two points of intersection. However, in some cases, they may not intersect at all.
3. How can I find the coordinates of the points of intersection?
To find the coordinates of the points of intersection, you can solve the equations of the circle and parabola simultaneously using algebraic methods such as substitution or elimination. You can also use graphical methods by plotting the two curves on a graph and finding the points of intersection visually.
4. What does the intersection of a circle and a parabola represent?
The intersection of a circle and a parabola represents the solutions to the system of equations formed by the two curves. In other words, it represents the values of x and y that satisfy both the equation of the circle and the equation of the parabola.
5. Can a circle and a parabola intersect at more than two points?
No, a circle and a parabola can only intersect at a maximum of two points. This is because a circle and a parabola are both second-degree curves and can only intersect at most twice.
