MHB Intersection Points & Finding Unknown Variable
The line with equation y = x + k intersects the parabola y = x^2 + x − 2 at two distinct points based on the value of k. Setting the equations equal leads to the quadratic equation 0 = x^2 - 2 - k. The discriminant method is applied, revealing that for two distinct intersection points, k must be greater than -2. If k equals -2, there is only one intersection point, while k less than -2 results in no real solutions. Thus, the critical condition for intersection is k > -2.
confusedatmath
The line with equation y = x + k, where k is a real number, intersects the parabola with equation y = x^2 + x − 2 in two distinct points if
I first made the equations equal each other
x + k = x^2 + x − 2
0 = x^2 -2 -k
From here i thought you use the discriminate a=1 b=o c=-2-k
but this isn't right, because the answer to choose from
k < − 2
k > − 2
k = − 2
k < 2
k ≠ 2
Mathematics news on Phys.org
confusedatmath said:
The line with equation y = x + k, where k is a real number, intersects the parabola with equation y = + x − 2 in two distinct points if
x + k = + x − 2
0 = -2 -k
k < − 2
k > − 2
k = − 2
k < 2
k ≠ 2
Hello.
Check the wording of the question. The parable, need that 'x' is not high to the power 1. (would be a straight line)
Regards.
mente oscura said:
Hello.
Regards.
i fixed it :p read again, it was a mistake i forgot the x^2
x + k = x^2 + x − 2
0 = x^2 -2 -k
k < − 2
k > − 2
k = − 2
k < 2
k ≠ 2
Now yes.
0=x^2-2-k
x^2=k+2
x=\pm{} \sqrt{k+2}
1º) k&lt;-2 \rightarrow{}x \cancel{\in}{R}
2º) k&gt;-2 \rightarrow{}x \in{R}
3º) k=-2 \rightarrow{}x=0, only a breakpoint.
Regards.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
