Interstellar radiation field between 0.1 microns and 1000 microns
Your Name]In summary, the conversation discusses the production of diffuse gamma-rays in the Galaxy through the inverse Compton process, where cosmic-ray electrons and positrons interact with low energy target photons from stars and dust. Accurate models of the Galactic stellar and dust distribution are crucial in calculating the resulting radiation field and spectrum, which is further influenced by absorption and scattering processes. The inclusion of a dust heating code allows for a better understanding of the infrared radiation field and its impact on the diffuse IC gamma-ray spectrum. This research provides valuable insights into high-energy astrophysical processes and their complex interactions in the Galaxy.
Danny
Cosmic-ray electrons and positrons propagating in the Galaxy produce diffuse gamma-rays via the inverse Compton (IC) process.
The low energy target photon populations with which the cosmic-rays interact during propagation are produced by stars, this stellar light being reprocessed by Galactic dust.
Detailed modelling of the Galactic stellar distribution, dust distribution, and treatment of the absorption and scattering of light is therefore required to obtain accurate models for the low energy Galactic photon distribution and spectrum. Using a realistic Galactic stellar distribution model, and dust distribution, we calculate the diffuse radiation field from stars in the Galaxy (the `optical' radiation field), including absorption and scattering. Using a dust heating code, we self-consistently calculate the infrared radiation field for the same dust model used for the optical calculation; both transient and equilibrium heating are included.
We present the calculated radiation field spectra and distributions, and will use these to calculate the expected Galactic diffuse IC gamma-ray spectrum.
Wow!
http://uk.arxiv.org/abs/astro-ph/0507119"
Thank you for sharing this interesting research on the production of diffuse gamma-rays in the Galaxy through the inverse Compton process. It is fascinating to see how cosmic-ray electrons and positrons interact with low energy target photons from stars and dust, leading to the generation of gamma-rays.
Your use of a realistic Galactic stellar and dust distribution model is crucial in accurately calculating the diffuse radiation field and spectrum. I am curious to know more about the absorption and scattering processes that are taken into account in your model. Can you elaborate on how these factors affect the resulting radiation field spectra and distributions?
Additionally, your inclusion of a dust heating code to calculate the infrared radiation field is a crucial step in understanding the transient and equilibrium heating processes. How do these different heating mechanisms impact the resulting radiation field and ultimately, the expected Galactic diffuse IC gamma-ray spectrum?
Overall, your research provides valuable insights into the complex interactions between cosmic rays, stars, and dust in the Galaxy. I look forward to learning more about your findings and their implications for our understanding of high-energy astrophysical processes.
I find this content to be very interesting and relevant to our understanding of interstellar radiation and its effects on cosmic-ray particles. The inverse Compton process is a well-known phenomenon in which high energy electrons and positrons interact with low energy photons, resulting in the production of diffuse gamma-rays. This process is important in understanding the propagation of cosmic rays in our Galaxy.
What is particularly intriguing about this content is the mention of the Galactic stellar distribution and dust distribution, and how they play a crucial role in determining the low energy photon distribution and spectrum. It is essential to accurately model these factors in order to obtain a comprehensive understanding of the interstellar radiation field.
The inclusion of a dust heating code in the calculations is also noteworthy, as it allows for a more comprehensive and self-consistent approach to determining the infrared radiation field. This is important as both transient and equilibrium heating are taken into account, providing a more accurate representation of the dust's impact on the radiation field.
Overall, this content highlights the complex and interconnected nature of interstellar radiation and its various sources and effects. I look forward to seeing the results of the calculated radiation field spectra and distributions, and how they contribute to our understanding of the diffuse IC gamma-ray spectrum in the Galaxy.
Related to Interstellar radiation field between 0.1 microns and 1000 microns
1. What is an interstellar radiation field?
An interstellar radiation field refers to the electromagnetic radiation present in the space between stars. It is a combination of various forms of radiation, including cosmic rays, x-rays, and ultraviolet, infrared, and visible light.
2. What is the range of wavelengths of the interstellar radiation field?
The interstellar radiation field covers a wide range of wavelengths, from 0.1 microns (or 100 nanometers) to 1000 microns (or 1 millimeter). This includes both the shorter, higher energy wavelengths and the longer, lower energy wavelengths.
3. Where does the interstellar radiation field come from?
The interstellar radiation field is made up of a combination of sources. Some of the radiation comes from stars, such as our Sun, while other sources include remnants of supernova explosions and cosmic rays from outside our solar system.
4. How does the interstellar radiation field affect objects in space?
The interstellar radiation field can have various effects on objects in space, depending on their composition and location. For example, the high energy radiation can cause damage to electronic equipment, while the lower energy radiation can heat up and ionize gases in the interstellar medium.
5. How is the interstellar radiation field studied?
Scientists use various methods to study the interstellar radiation field, including space telescopes, ground-based telescopes, and computer simulations. They also use data from spacecraft, such as the Voyager and Cassini missions, to gather information about the interstellar radiation field in different regions of space.
  • Beyond the Standard Models
  • DIY Projects
  • Biology and Medical
