Intro thermodynamics question (simple piston cylinder)
In summary, the problem involves a piston-cylinder device with a mass of 5 kg of a saturated liquid-vapour mixture at 100 kPa and 2 kg of water in the liquid phase (State 1). Heat is transferred, causing the piston to move and the volume to increase by 25% (State 3). The questions involve finding the temperature in State 1, the volume in State 1, the temperature in State 3, determining if State 2 is in the 2-phase region or the superheated vapour region, showing the process on a P-v diagram, calculating the work done during the process, and finding the total heat transferred. In the second problem, ethylene enters an
slashrulez
A mass of 5 kg of saturated liquid -vapour mixture is contained in a piston-cylinder
device at 100 kPa (see Figure 1). Initially 2 kg of water is in the liquid phase and the
rest is in the vapour phase (State 1). Heat is transferred to the water and the piston,
which is resting on a set of stops, starts moving when the pressure inside reaches 200
kPa (State 2). Heat transfer continues until the total volume is increased by 25% (State
3).
(2) (a) Find the temperature in State 1.
(4) (b) Determine the volume in State 1.
(4) (c) What is the temperature in State 3?
(3) (d) Is State 2 in the 2-phase region or in the superheated vapour region?
(4) (e) Show the process on a P-v diagram with respect to the saturation lines; points
1-3 must be labeled and the direction of the process indicated.
(3) (f) What is the work done during this process?
(5) (g) Calculate the total heat transferred to the system.
No need to include the figure, it's pretty much a piston sitting on some stops.
Errmm...none I think
My question is in regards to part c, and then part e. I know that in state 2 it's a superheated vapour because I know the pressure, so I can compare specific volumes and whatnot. My problem is that I don't really know how to find anything about state 3 with the info given. All I know is that the volume goes up, so I can find the new specific volume, but past that I don't know. I don't have any info about the pressure, and all I know is that the temperature is probably more than it is in state 2. I want to assume the pressure stays constant between 2 and 3, since I could work with the specific volume and pressure to figure out the temperature pretty easily, but I don't know if I can assume that without the question stating it. As for part e, I can't really calculate boundary work without knowing the pressure, so figuring out c will probably make it straightforward.
So pretty much I'm thinking that I can assume the pressure stays constant during the expansion. Other than that, I have no idea
Going to add another question that's been giving me some difficulty.
4. Ethylene, C2H4, enters an adiabatic turbine at 10.24 MPa and 339 K (State 1). The
ethylene exits the turbine at 228 K with a quality of 95% (State 2a).
Data for ethylene:
Tc = 282.4 K
Pc = 5.12 MPa
R = 0.2964 kJ/(kg.K)
Cp0 = 1.5482 kJ/(kg.K)
Use the generalized charts to calculate the following:
(5) (a) The specific volume of the ethylene at the inlet of the turbine, in m3/kg.
(10) (b) The work output of the turbine, in kJ/kg.
(10) (c) The quality at the exit of an isentropic turbine operating between the same
inlet conditions and the same exit pressure as the turbine above (State 2s).
(a) I think I know how to do this. I just set up Pv = ZRT and figured out Z from the lee-kesler diagram, then solved for v
(b) I'm not sure on this. I mean, I assume I should start with Q - W = del U, and since it's adiabatic I just need to find the change in internal energy. At first I thought I would need to use the charts to do some type of enthalpy/entropy departure calculation, but none of that relates to internal energy. My only other guess is to say R = Cp - Cv and solve for Cv, and then say del U = Cv(T2 - T1). That seems way too easy to me, plus I'm guessing the first relation only works for ideal gases, but I think the second relation would hold since I don't think my volume is changing. Another thing that worries me is that I never used the quality given in the question, so unless they put it in there to trick me I might be missing something.
(c) This part really has me confused, although I haven't really put much work into it. If the turbine is already adiabatic, would it being reversible change anything? And if so, I really have no idea how to go about solving this. I'm guessing I would need to use the entropy departure chart thing, but I really don't know beyond that. I was also thinking of using the relationships T2/T1 = (P2/P1)^[(k-1)/k] and T2/T1 = (v1/v2)^(k-1) where k = Cp / Cv, but again that's based on me deriving Cv, and I'm not even sure if that would get me anywhere. I was just thinking that if I knew the specific volume, temperature and pressure, quality wouldn't be too hard to get. Not sure how to do it with a non-ideal gas though
Related to Intro thermodynamics question (simple piston cylinder)
1. What is thermodynamics?
Thermodynamics is the branch of physics that deals with the study of heat and its relationship with other forms of energy, such as work and temperature. It also includes the study of how energy is transferred and transformed in various systems.
2. What is a piston cylinder?
A piston cylinder is a simple device used in thermodynamics experiments to study the relationship between pressure, volume, and temperature. It consists of a cylinder with a moveable piston that can compress or expand the gas inside, allowing for the measurement of these properties.
3. What is the first law of thermodynamics?
The first law of thermodynamics, also known as the law of conservation of energy, states that energy cannot be created or destroyed, but it can be transferred from one form to another. In other words, the total energy of a closed system remains constant.
4. How does a piston cylinder demonstrate the first law of thermodynamics?
A piston cylinder experiment can demonstrate the first law of thermodynamics by showing that the total energy of the system (the gas inside the cylinder) remains constant, even as the pressure, volume, and temperature change. This is because any energy added or removed from the system is accounted for in the form of work or heat.
5. What is the significance of the ideal gas law in thermodynamics?
The ideal gas law is a fundamental equation in thermodynamics that describes the relationship between the pressure, volume, and temperature of an ideal gas. It is important because it allows for the prediction of gas behavior under various conditions, and it serves as the basis for many thermodynamic calculations and experiments.
10K
31K
  • Thermodynamics
