C/C++ Intro to c++ help with vector problem
  • Thread starter Thread starter medonaldson2
    C++ Intro Vector
The discussion focuses on a coding problem involving populating a vector with user input integers in C++. The initial code attempts to read integers into a vector but produces an incorrect output due to an attempt to access an out-of-bounds index. The output includes an unexpected zero because the index variable `i` exceeds the valid range after the loop. A solution is provided that correctly outputs the vector's contents by using a separate loop to print each element, ensuring that the output format meets the requirements. Key points include the importance of managing vector indices properly and the limitation of the `cout` function, which cannot directly output vectors.
medonaldson2
So I'm trying to do this problem:
Write a for loop to populate vector userGuesses with NUM_GUESSES integers. Read integers using cin. Ex: If NUM_GUESSES is 3 and user enters 9 5 2, then userGuesses is {9, 5, 2}.
Here is my code so far...
Code:
#include <iostream>
#include <vector>
using namespace std;
int main() {
   const int NUM_GUESSES = 3;
   vector<int> userGuesses(NUM_GUESSES);
   int i = 0;
   for (i = 0; i < NUM_GUESSES; i++) {
      cin >> userGuesses[i];
   cout << userGuesses[i];
   return 0;
The output is when tested with values {2, 4, 6}
02 4 6
The output needs to be...
2 4 6
I don't know why the zero is there. Any ideas?
thanks
Technology news on Phys.org
I managed to get the desired output with
Code:
#include <iostream>
#include <vector>
int main() {
		int i;
		cout << '\n';
			cout << userGuesses[i] << ' ';
		cout << '\n';
		return 0;
I made some minor changes. Hopefully you can spot them. :)
The problem with your code is at the line:
Code:
cout<<userGuesses[i];
When this is executed, the value of i is 3!. But userGuesses has components at 0, 1 and 2. There is no component v[3]. The standard says (I looked it up) that this causes no run time error, but the result could be any thing. The member function at of vector, userGuesses.at(i), has the same behavior as [], but will "throw an exception" since there is no such component of userGuesses. The exception causes immediate exit from the program. So when using a vector, it is up to the programmer to ensure any reference using [] is a valid component of the vector.
greg1313 has shown you a correct program. Notice he uses a loop to output the contents of userGuesses. You can not write cout<<userGuesses; i.e. cout does not accept vectors to output.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
15K
