MHB Introduction to RAD (Rapid Application Development)
  • Thread starter Thread starter karush
    Bicycle Speed
The discussion revolves around calculating the speed of a bicycle with tires that have a radius of 13 inches, turning at a rate of 200 revolutions per minute. The calculation yields a speed of approximately 15.5 miles per hour, confirming the method used. Participants clarify that "rev" is dimensionless, which aids in the calculation process. One user expresses a desire to start a new thread to seek further clarification on Rapid Application Development (RAD). The conversation effectively combines mathematical reasoning with practical application.
karush
MHB
The tires of a bicycle have radius of $13 \text{ in}$ and are turning at a rate of
$\displaystyle\frac{200\text{ rev}}{\text{min}}$
How fast is the bicycle traveling in
$\displaystyle\frac{\text{mi}}{\text{hr}}$
well my try on this is.
\displaystyle 26\pi\text{ in }
\cdot
\frac{200\text{ rev}}{\text {min}}
\cdot
\frac{\text {ft}}{12\text{ in}}
\cdot
\frac{\text {mi}}{5280\text{ ft}}
\cdot
\frac{60\text { min}}{\text{ hr}}
\approx\frac{15.5\text { mi}}{\text{ hr}}
no answer given so hope this is it..:cool:
assume "rev" not a unit measure but doesn't cancel out so its not carried thru..
Mathematics news on Phys.org
Re: speed of a Bicycle
\cdot
\cdot
\cdot
\cdot
Yep. That is it.
And indeed, "rev" is not a unit measure - it's dimensionless.
Or if you want, you have $2\pi \cdot 13 \text{ in/rev}$, making it cancel out nicely.
I like Serena said:
Yep. That is it.
cool tip..
I am going to start another thread with one that is:confused: to me. I don't understand RAD...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
