MaximusDecimus
- 2
- 1
OP warned about not using the homework template
Hello i am new,
I have written this piece for homework with reference, and wondering how i can write it better.
Maybe i have written too much or too little, i would appreciate some help.
Regards.
Little gLittle g, what is considered as G-Force or Gravitational Force is the force in which Gravity itself has effect on, for example we as people are subjected to G-Force, a car accelerates produces G-Force, as it will break suddenly or decelerate, or turn sharply this is also under G-Force conditions.
It seems that our planet has a Gravitational Force in which we can observe and in fact, almost all physical objects are subject to it its own G-Force, but it is the Earths Gravitational Force which overpowers them all.
Gravitational Force attracts object of Mass towards each other, it is G-Force that causes the acceleration of these physical objects, an object on incline plane will fall due to gravity, the movement of the object is because of Gravitational Force.
So little g stands for the amount of Acceleration cause by Gravity, also referred to as G-Force (Gravitational Force) and the big G is Newton’s [1] Gravitational Constant. The Newtonian Constant of Gravitation is used to calculate the attractive force of gravity between objects. Big is G is still only a known value to 3 significant figures.
The gravitational constant Big G, little g, the acceleration due to Earth's gravity. The little g value is dependent upon the location as the earth’s surface has slight variations. These varying from density of geologic structures , this also means that the Earth may not be perfectly spherical, in that the Earth's surface is further from its center at the equator than it is at the poles.
[ref] PHYS.ORG
Regards.
[ref] PHYS.ORG
