Intuition behind fields in Transmission lines
In summary, traveling waves can exist on transmission lines even if the wires are perfect conductors because of the interaction between the electric and magnetic fields near the wire. While the electric potential on the wire is zero, moving electrons create a magnetic field that carries the energy along the transmission line. This phenomenon is described by Maxwell's Equations and the Telegrapher's equations. The shape of the traveling wave can change along the line, even in the case of a constant DC source, due to the inherent inductance and resistance of the line.
Amartansh
TL;DR Summary
How can travelling wave exist on transmission line if wires are perfect conductors (how voltages can be different at different positions on one perfect conductor)?
How can traveling wave exist on transmission line if wires are perfect conductors (how voltages can be different at different positions on one perfect conductor)? I mean electric fiels should be zero on equipotential source. I know if length is too long compared to wavelength, we get phase difference on each point. But if all the connected points on conductor have same potential, how voltage/ electric field can vary and if electric field cannot vary then how current varies. Also, if inductance of line causes variation then how this inherent inductance is explained in these conductors? I know the classical reasons but looking better intuition and physical insight into this phenomenon.
While the electric potential on the wire is zero, moving electrons create a magnetic field near the wire which interacts with the electric field near the wire. In fact the energy carried down the transmission line is really carried "around" (i.e. nearby) the transmission line. You will hear a lot about this when you get into the Electricity and Magnetism part of your physics education. You can not figure this out if you ignore the magnetic fields.
If you want a head start, look into "Maxwell's Equations".
Likes Amartansh
You seem to confuse electrostatic or/and magnetostatic state condition with electrodynamic case. The traveling waves on Tx lines propagate at speed close to the speed of light so distant points on the line need not to be at same potential and with same currents at the same time. For example, if constant DC source suddenly gets connected (switched on) to uniform loseless TX line, than the wave propagates without change of the shape along the line (and you would be kind of right). If the source is not constant, and line is still losess than the shape of the launched wave changes in accordance with the source and propagates as such. In reality the line is lossy and shape of traveling wave changes from point to point even in the case of switched on constant DC source. Such Transients (and more) on TX lines are described by the Telegrapher's equations
Likes anorlunda, Amartansh and DaveE
FAQ: Intuition behind fields in Transmission lines
What is the purpose of using fields in transmission lines?
The purpose of using fields in transmission lines is to transfer energy from one point to another. Fields, specifically electric and magnetic fields, are used to carry the energy through the transmission line and deliver it to the intended destination.
How do fields in transmission lines work?
Fields in transmission lines work by creating a path for energy to travel through. Electric fields are created by the voltage difference between two points, and magnetic fields are created by the flow of current. These fields interact with each other, allowing the energy to be transferred through the transmission line.
What is the difference between electric and magnetic fields in transmission lines?
Electric fields are created by the voltage difference between two points and are responsible for the movement of charged particles. Magnetic fields, on the other hand, are created by the flow of current and are responsible for the force on moving charged particles. In transmission lines, both electric and magnetic fields work together to transfer energy.
Why is it important to understand the intuition behind fields in transmission lines?
Understanding the intuition behind fields in transmission lines is important for designing and optimizing transmission systems. By understanding how fields work, scientists and engineers can create more efficient and reliable transmission lines, leading to better energy transfer and distribution.
How do fields in transmission lines affect the overall performance of the system?
Fields in transmission lines play a crucial role in the overall performance of the system. They determine the amount of energy that can be transferred, the speed at which it can be transferred, and the overall efficiency of the system. By understanding and controlling these fields, scientists and engineers can improve the performance of transmission lines and ensure reliable energy delivery.
