Intuition behind two manifolds being the same.
In summary: I guess what I'm saying is that there's something more fundamental at play here. There has to be a reason why infinitely differentiable is the best definition.I would think that this definition would have to capture the other notions we have for differential manifolds such as curvature etc. But then I would guess there exist a theorem which states that any two (differentiable) manifolds which are diffeomorphic have the same curvature. Does it?There is no single theorem that captures this, it's more of a philosophical concept. But in general, if two manifolds are diffeomorphic then there is a smooth map between them which is differentiable and preserves the metric tensor.
center o bass
560
In Sean Carroll's general relativity book he gives a requirement that two (differentiable) manifolds be the same manifold that there exist a diffeomorphism ##\phi## between them; i.e. a one-to-one, invertible and ##C^{\infty}## map.
Now I wanted to get some intuition why this is the best definition on what we mean by sameness.
A manifold as I understand it so far is loosely an abstract collection of objects (a set) along with all possible, fully covering, coordinate systems (a maximal atlas). For example, the set of points on the two-sphere ##S^2## along with all different ways of describing all these points by associating them with numbers (obeying certain conditions such as being one-to-one).
Different choices of atlases only reflects different methods of numbering the different objects in the set, and it's clear that if two sets should be the "same", they would have to exist a one-to-one map between them. But why would we require that this relation be infinitely differentiable?
Any enlightening words are appreciated!
Because we're talking about differential manifolds. For plain old topological manifolds, all we care about is that the map is continuous.
And for (pseudo)-Riemannian manifolds, we want the map to be differentiable AND preserve the metric tensor (then it will also preserve the curvature).
Will a diffeomorphism preserve the metric tensor? If so can you refer me to any theorems on this?
Not necessarily. A diffeomorphism preserves the smooth structure. An isometry preserves the metric tensor (Riemannian or pseudo-Riemannian structure). There's no theorem here, it's just a definition. An isometry is a diffeomorphism that preserves the Riemannian of pseudo-Riemannian structure. Just a note on terminology, the term isometry is also used in the context of metric spaces.
So a diffeomorphism between two manifolds (which per definition implies they being the same manifold) does not imply that the two (differentiable) manifolds have the same curvature?
In what sense are the two manifolds then the same?
And how is GR diffeomorphism invariant if the curvature is not invariant under diffeomorphisms?
A diffeomorphism just preserves the smooth structure; two diffeomorphic manifolds are the same as far as their smooth structures go just like two homeomorphic topological spaces are the same as far as their topologies and topological properties go.
GR is diffeomorphism invariant in the sense that the gauge group of GR (under the EFEs) is the diffeomorphism group of the underlying (differentiable) space-time manifold. These are diffeomorphisms that are also endomorphisms i.e. ##\varphi: M\rightarrow M## such that ##\varphi## and ##\varphi^{-1}## are smooth.
You need to make sure that the inverse is smooth as well.
There are bunches of ways of thinking about this, but here's one that I like. Basically if two smooth manifolds M and N are diffeomorphic, then the idea is that anything we can prove about M using only its manifold structure (topology, atlas, etc.) should also be provable for N and vice versa. So in some sense they are formally the same object.
Pretty much. Just want to clarify that your coordinate systems need to be compatible. So the transition from one coordinate system to another should be smooth.
Yes thinking about coordinates as just applying labels (locally) to the points is a good way to internalize things. Just having a bijective map between the underlying sets of points is not good enough. This map is only guaranteed to prove set-theoretic properties like the size of the set. For example there is a bijective map between R and R2 but clearly the geometry/topology of these spaces are different. Requiring the diffeomorphism to be smooth is just there to require that the manifold properties are preserved.
You probably need a stronger notion of equivalence to make sure that curvature is preserved. The curvature of a manifold is not intrinsic to the smooth structure, but rather comes from a metric or connection on the manifold. So a stronger equivalence like isometry would do the trick.
Edit: Ben Niehoff and WannabeNewton beat me to it! I type too slow guyz :'(
jgens said:
Edit: Ben Niehoff and WannabeNewton beat me to! I type too slow guyz :'(
*poke*...*poke*
I would call it a definition of sameness. Essentially, we are defining something called an equivalence relation between differentiable manifolds. There are many other equivalence relations we could define. We can say that they are "the same" if there exists a homeomorphism between them, for example. We can also say that they are "the same" if they both look like the same brand of pancake batter when embedded in ##\mathbb{R}^n## (good luck doing this rigorously). It depends on what you are interested in looking at. In this case, what is interesting about differentiable manifolds?
As an aside, I think we can exploit the inverse function theorem to obtain this.
Give R it's usual smooth structure. Then the map f:RR given by f(x) = x3 is smooth and bijective but is not a diffeomorphism.
I have just studied differential geometry in relation to general relativity (no topology), so that the "smooth structure" of a manifold does not include the concept of curvature seem a bit strange to me. I have to say that I'm a bit disappointed that the mathematicians did not include the concept of curvature into the definition of "sameness". Perhaps I will not be in the near future when I learn more about these things. Anyway; what is the definition of the "smooth structure" of the manifold? Is it just it's level of differentiability?
With some further thought I guess I could agree with the definition from the fact that a manifold is just a set of objects with no apriori notion of distance between them, and thus no notion of curvature. But then how does one say that a manifold has (for example) a spherical geometry? Can one state that without reference to the metric?
A smooth structure (also called maximal smooth atlas) is usually taken to be a maximal collection of smoothly compatible charts on a given topological manifold ##M## (you really don't even need a pre-existing topology, you can construct a smooth atlas on a set and it will naturally induce a topology that is e.g. Hausdorff, second countable, and locally Euclidean).
What you are overlooking is that there are various types of sameness for a given object. We can look at sameness at the topological level (under homeomorphisms), at the differentiable level (under e.g. diffeomorphisms), and at the level of the metric tensor (under isometries).
In GR, you have to realize that the underlying smooth structure of space-time is more fundamental than the pseudo-Riemannian structure in the sense of general covariance. If ##g_{ab}## represents a certain space-time geometry then ##\varphi^{*}g_{ab}## will represent the exact same space-time geometry, where ##\varphi \in \text{diff}(M)##
The smooth structure is just the maximal smooth atlas. If you want a notion of sameness that includes curvature, then just look at isometry.
Generally when one makes statements like that there is some metric or connection floating around. I suppose there are some cases where the topology/manifold structure can determine something about what kinds of metric are allowed. For example it's not too difficult to show that S4 does not admit a Lorentzian metric. But for the most part statements like "has a spherical geometry" have a metric lurking somewhere.
Edit: Beaten again. So many sad faces.
Again, sameness can be defined differently. We can define two Riemannian manifolds to be "the same" if there exists an isometric map between them. We can define sameness by looking at what we are interested in.
I'm speaking of a generalization that says, if ##f:M\to N## is a differentiable map between smooth manifolds and ##df_p:T_pM\to T_{f(p)}N##, with ##p\in M##, is an isomorphism, then there exists an open neighborhood of ##p## such that ##f## restricted to that neighborhood is a diffeomorphism. I was giving the OP a way to confirm a given map is a diffeomorphism, not prove his statement was correct. :-p
That doesn't tell you if a given map is a diffeomorphism. Taking again my significant other jgens' example, ##f:\mathbb{R}\rightarrow\mathbb{R}## given by ##f(x) = x^3## is differentiable and ##df_p## is an isomorphism hence ##f## satisfies the criteria for the inverse function theorem, but ##f## is not a diffeomorphism. It just tells you that ##f## is a local diffeomorphism.
EDIT: unless you're talking about a smooth function that fails to satisfy the inverse function theorem in which case yes certainly there is no way it can be a diffeomorphism.
So when one talks about the manifold ##M=S^2##, i.e. the two-sphere, one is talking about the set of points on the sphere equipped with the metric ##\sin ^2 \theta d\phi^2 + d\theta^2## (here expressed in spherical coordinates)?
Yeah unless it's stated otherwise, the standing assumption when you see something like R or S2 is that the usual topology and smooth structures and metrics are taken.
It depends entirely on the context. I can simply look at properties of ##S^2## as a topological manifold (i.e.the fact that it's connected, compact, has a trivial fundamental group etc.). I can further look at properties that emerge after introducing the standard smooth structure on ##S^2##. Even further, I can look at properties that emerge after introducing the standard metric tensor ##g_{ab}## on ##S^2## such as the Riemann curvature tensor ##R_{abc}{}{}^{d}\omega_d = 2\nabla_{[a}\nabla_{b]}\omega_{c}## where ##\nabla_a## is associated with ##g_{ab}##. So to reiterate, it depends entirely on the context.
If ##f## satisfies the given conditions of our inverse function theorem (id est ##f## is a "local diffeomorphism"), for all ##p\in M##, isn't it a diffeomorphism?
Oops sorry the above example isn't diffeomorphic on any neighborhood of 0 (I always forget about 0!) but with regards to what you said, if on top of that the map is also bijective then yes. A smooth map between two smooth manifolds is a diffeomorphism if and only if it is a bijective local diffeomorphism.
By the way, with regards to this, a local isometry preserves the Riemann curvature tensor in case you were interested.
Two manifolds which are diffeomorphic do not have to have the same curvature. A sphere is diffeomorphic to an ellipsoid, for example.
The smooth structure and the geometric structure are different!
Most of the time in GR, you really don't care about the smooth structure beyond the simple fact that there IS one. I think GR texts tend to make way too big a deal about diffeomorphisms, even to the point of saying "diffeomorphism" when they really ought to say "coordinate transformation". A coordinate transformation is a local isometry; it is actually something more than a diffeomorphism.
Any book that tells you the Einstein equations are "diffeomorphism invariant" is lying. First of all, the Einstein equation has free indices, so at best it can be covariant, not invariant. Second, the Einstein equations are "local isometry covariant", or "generally covariant under coordinate transformations", but as my above example with spheres and ellipsoids shows, they can't possibly be "diffeomorphism covariant", because diffeomorphisms allow you to change the geometric structure, as long as you do so smoothly.
Indeed. In Sean Carroll's book, he states that a diffeomorphism is an active coordinate transformation. Could you define a local isometry and elaborate on the difference between diffeomorphisms and coordinate transformations?
FAQ: Intuition behind two manifolds being the same.
1. What is a manifold?
A manifold is a mathematical concept that describes a space that is locally similar to Euclidean space, but may have a more complex structure overall.
2. How can two manifolds be considered the same?
Two manifolds can be considered the same if there exists a continuous and bijective mapping between them, meaning every point on one manifold can be uniquely mapped to a point on the other manifold.
3. What is the intuition behind two manifolds being the same?
The intuition behind two manifolds being the same is that they have the same underlying structure, even if they may look different on the surface. This can be visualized by imagining two different maps of the same city - they may have different orientations and labels, but they represent the same underlying city.
4. Can two manifolds be considered the same if they have different dimensions?
No, two manifolds must have the same dimension in order to be considered the same. This is because the dimension of a manifold determines its intrinsic properties, and a continuous and bijective mapping between two manifolds must preserve these properties.
5. Are there any real-life applications for understanding the intuition behind two manifolds being the same?
Yes, understanding the intuition behind two manifolds being the same is important in fields such as physics, computer science, and data analysis. In physics, manifolds are used to describe the curvature of space-time in general relativity. In computer science, they are used in machine learning algorithms to analyze and classify complex data sets. And in data analysis, they can help identify patterns and relationships between different data points.
