Intuition for sign of third derivative
In summary, the underlined properties are easy to understand, global, and easy to state without having defined a derivative.
economicsnerd
269
24
[I asked this question over a year ago, but I thought I'd try again.]
Let ##I\subseteq \mathbb R## be an interval and ##f:I\to\mathbb R## be a ##C^\infty## function.
I have the following characterizations:
1) ##f'\geq 0## everywhere iff ##f## is increasing.
2) ##f''\geq 0## everywhere iff ##f## is convex.
The underlined properties above are very nice for a couple reasons:
- They're easy to interpret/visualize. e.g. An increasing function is one with all secant lines having slope ##\geq 0##; a convex function is one with all secants lying above its graph.
- They're both global properties.
- They're both easy to state without having defined a derivative. That is, I can define an increasing function or a convex function, even if my audience doesn't understand what a derivative is.
Is there a nice interpretable condition which is equivalent to ##f'''\geq0##? Ideally, I'd be interested in a condition which (like monotonicity and convexity) is global and makes no reference to differentiation.
I guess f''' > 0 means the function is getting tightly more curved upward as the independent variable increases.
It is hard to visualize this with functions like f(x)=x^3 in the interval [-1,0] as the function is not curved upwards. "More upwards" in the sense of a larger second derviative, sure, but it's hard to understand that in an intuitive way.
Huh?
The third derivative of f(x)=x^3 is 6 everywhere, and 6>0.
mfb said:
Huh?
I stand corrected. I deleted my incorrect answer.
well x^3 is going from curved downwards to curved upwards, so it is getting more curved upwards in a sense as you move to the right. unfortunately the curvature is not exactly proportional to the second derivative, so although the second derivative is increasing the curve itself is apparently straightening out to the right. what is the formula for the curvature of y = x^3, anyway?
it seems to be |f''|/{1 + (f')^2}^(3/2). good grief. so we get |6x|/(1+9x^4)^(3/2), hmmmm. well anyway that's why it is straightening out.
How about:
Given two points A and B where B is to the right of A : a function with f"'>0 is one which at B lies above any parabola which is osculating at A. [by osculating I mean it matches f in respect of ordinate, slope and second derivative].
Not particularly nice I suppose
Likes mfb
I think I found one that works okay.
For some fixed ##d>0## and ##\lambda\in(0,1)##, let ##g(x)## denote the "gap" between the graph of ##f## and its secant between ##x## and ##x+d##, measured proportion ##\lambda## of the way along. That is, let ##g(x):= [\lambda f(x+d) + (1-\lambda) f(x)] - f(x+\lambda d)##. What a positive third derivative requires is that this gap be increasing in ##x##.
One could explain that to a person with no calculus training, right?
I guess it is possible to prove that statement with a taylor approximation to second order and a remainder which uses the third derivative. Then use that this derivative is positive everywhere.
Didn't check it in detail, but I also did not find a counterexample and the proposed formula looks reasonable.
Related to Intuition for sign of third derivative
1. What is intuition for the sign of third derivative?
The third derivative of a function represents the rate of change of the second derivative. Intuitively, it tells us whether the rate of change of the rate of change is increasing or decreasing at a specific point on the function.
2. How is the sign of the third derivative related to the concavity of a function?
The sign of the third derivative can be used to determine the concavity of a function. If the third derivative is positive at a point, the function is concave up at that point. If the third derivative is negative, the function is concave down at that point.
3. Can the third derivative be zero?
Yes, the third derivative can be zero. This means that the rate of change of the second derivative is not changing at that point on the function. In other words, the function is neither concave up nor concave down at that point.
4. How can the third derivative help us analyze the behavior of a function?
The third derivative can provide valuable information about the behavior of a function. For example, if the third derivative is positive and increasing, the function is experiencing accelerating concavity. If the third derivative is negative and decreasing, the function is experiencing decelerating concavity.
5. Is the third derivative always necessary in calculus?
No, the third derivative is not always necessary in calculus. It can be used to gain a deeper understanding of a function and its behavior, but it is not always required for basic calculations and analysis.
  • Differential Equations
  • Topology and Analysis
  • Differential Geometry
