I Intuition regarding Riemann curvature tensor
Hill
TL;DR Summary
"Why" there are terms quadratic in first derivatives of metric?
The Riemann curvature tensor contains second derivatives of metric and squares of the first derivatives. The second derivatives have to be there because they are the ones that cannot be eliminated locally by a choice of coordinates. But other than being a mathematical artifact, is there a meaning for the squares of the first derivatives to be there?
The first derivatives tell you directions. Curvature can be different in different directions. And the curvature in one direction can change as you move in a different direction
Likes Hill and vanhees71
If you look at how this actually works, you find that in Riemann normal coordinates, which are the ones that eliminate everything that can be eliminated by a choice of coordinates, the first derivatives are zero at the origin of coordinates, i.e., at the point the coordinates are "centered" on. So at that point, the first derivatives indeed do not appear at all in the Riemann tensor.
But as soon as you move away from the origin, the first derivatives are no longer zero (because the second derivatives weren't zero at the origin), and they will be different depending on which direction you move. So you do need them to capture the complete behavior once you are away from the origin.
Likes Hill and Dale
lndeed, a zero second derivatives w.r.t. a coordinate basis at the origin, would mean constant first derivatives in a neighborhood of the origin, but first derivatives by definition vanish at the origin in Riemann normal coordinates centered on it.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
